I've found some issues with the batch files
mpicc.bat
and
mpifc.bat
when trying to compile a C++ mpi program.
the batch files contain
echo.
statements which are illegal on windows.
I've had this issue in the past with mpi Fortran code, but not C++ code.
Ian
Thanks for posting in the Intel forums.
>>> "I've found some issues with the batch files"
Could you please elaborate more on this issue?
Could you please let us know the version of Intel MPI you have been using?
>>>" when trying to compile a C++ mpi program"
Could you please provide us with the sample reproducer and steps to reproduce the issue at our end?
Thanks & Regards
Shivani
Here are the outputs from the various
batch files that Intel provide.
C:\document\cpp\examples>mpicc ch3705.cxx
mpicc.bat for the Intel(R) MPI Library 2021.7 for Windows*
Copyright Intel Corporation.
'echo.' is not recognized as an internal or external command,
operable program or batch file.
C:\document\cpp\examples>mpicl ch3705.cxx
C:\document\cpp\examples>mpicxx ch3705.cxx
C:\document\cpp\examples>mpifc ch3705.cxx
mpifc.bat for the Intel(R) MPI Library 2021.7 for Windows*
C:\document\cpp\examples>mpiicc ch3705.cxx
C:\document\cpp\examples>mpiicpc ch3705.cxx
Here is the source code
#include <chrono>
#include <cmath>
using namespace std;
class timer
public:
timer() : start_timing(hi_res_clock::now()) {}
void reset()
start_timing = hi_res_clock::now();
double elapsed() const
return(std::chrono::duration_cast<second_>
(hi_res_clock::now() - start_timing).count());
private:
typedef std::chrono::high_resolution_clock hi_res_clock;
typedef std::chrono::duration<double, std::ratio<1> > second_;
std::chrono::time_point<hi_res_clock> start_timing;
#include <iostream>
#include <cassert>
#include <chrono>
#include <string>
#include <cstdlib>
#include <mpi.h>
void print_time(const string& heading, const double& t)
cout << heading << " : ";
cout.width(10);cout.precision(6);
cout.setf(ios::right);
cout.setf(ios::showpoint);
cout.setf(ios::fixed);
cout << t << endl;
void format_20_16()
cout.width(20);cout.precision(16);
void format_08_06()
cout.width(8);cout.precision(6);
double f(double x)
double f;
f = 4.0 / (1.0 + x * x);
return(f);
int main()
timer timer_01;
timer timer_02;
double t;
string heading;
double cplusplus_internal_pi;
double interval_width;
double partial_pi;
double partial_sum;
double total_pi;
double x;
double time_difference;
double* sendbuf;
double* recbuf;
int i;
int j;
int n_intervals;
int error_number;
int this_process;
int n_processes;
MPI_Init(NULL, NULL);
MPI_Comm_size(MPI_COMM_WORLD, &n_processes);
MPI_Comm_rank(MPI_COMM_WORLD, &this_process);
heading = "\n Program starts ";
if (this_process == 0)
t = timer_01.elapsed();
print_time(heading, t);
n_intervals = 1000000;
cplusplus_internal_pi = 4.0 * atan(1.0);
cout << "\n C++ internal pi 4.0*atan(1.0) \n" << endl;
cout << " ";
format_20_16();
cout << cplusplus_internal_pi << endl;
heading = " Loop time ";
for (j = 1; j < 5; j++)
interval_width = 1.0 / n_intervals;
partial_sum = 0.0;
for (i = this_process +1 ; i <= n_intervals; i = i + n_processes)
x = interval_width * (double(i) - 0.5);
partial_sum = partial_sum + f(x);
partial_pi = interval_width * partial_sum;
sendbuf = &partial_pi;
recbuf = &total_pi;
MPI_Reduce(sendbuf,
recbuf,
1,
MPI_DOUBLE,
MPI_SUM,
0,
MPI_COMM_WORLD);
time_difference = t;
timer_01.reset();
cout << " ";
cout << " N intervals ";
cout.width(12);
cout << n_intervals;
cout << " time = ";
format_08_06();
cout << time_difference << endl;
cout << " Calculated ";
format_20_16();
cout << total_pi << endl;
cout << " Difference ";
format_20_16();
cout << abs(total_pi - cplusplus_internal_pi) << endl;
n_intervals = n_intervals * 10;
t = timer_02.elapsed();
heading = " \n Total time ";
MPI_Finalize();
return(0);
I did a dir/s mpi*.bat and this is the output
Volume in drive C is OS
Volume Serial Number is 50BD-6CC8
Directory of C:\Program Files (x86)\Intel\oneAPI\mpi\2021.7.1\bin
21/10/2022 17:40 21,398 mpicc.bat
21/10/2022 17:40 1,036 mpicl.bat
21/10/2022 17:40 1,078 mpicxx.bat
21/10/2022 17:40 979 mpif77.bat
21/10/2022 17:40 979 mpif90.bat
21/10/2022 17:40 25,765 mpifc.bat
21/10/2022 17:40 1,033 mpiicc.bat
21/10/2022 17:40 1,037 mpiicpc.bat
21/10/2022 17:40 981 mpiifort.bat
21/10/2022 17:40 673 mpitune.bat
10 File(s) 54,959 bytes
Directory of C:\Program Files (x86)\Intel\oneAPI\mpi\2021.7.1\etc\conda\activate.d
21/10/2022 16:35 1,396 mpivars.activate.bat
1 File(s) 1,396 bytes
Directory of C:\Program Files (x86)\Intel\oneAPI\mpi\2021.7.1\etc\conda\deactivate.d
21/10/2022 16:35 1,990 mpivars.deactivate.bat
1 File(s) 1,990 bytes
Directory of C:\Program Files (x86)\Intel\oneAPI\mpi\latest\bin
Directory of C:\Program Files (x86)\Intel\oneAPI\mpi\latest\etc\conda\activate.d
Directory of C:\Program Files (x86)\Intel\oneAPI\mpi\latest\etc\conda\deactivate.d
Total Files Listed:
24 File(s) 116,690 bytes
0 Dir(s) 458,762,018,816 bytes free
I did a grep on the above batch files looking for "^echo"
and found that mpicc.bat and mpifc.bat both contains
echo.
statements.
Hope this helps
Ian
We are unable to reproduce the error at our end with Intel MPI 2021.7 version.
Please refer to the below for the output details.
C:\Users\karangux\Desktop>mpicc shivani.cpp
Microsoft (R) C/C++ Optimizing Compiler Version 19.30.30705 for x64
Copyright (C) Microsoft Corporation. All rights reserved.
shivani.cpp
C:\Program Files\Microsoft Visual Studio\2022\Professional\VC\Tools\MSVC\14.30.30705\include\ostream(410): warning C4530: C++ exception handler used, but unwind semantics are not enabled. Specify /EHsc
C:\Program Files\Microsoft Visual Studio\2022\Professional\VC\Tools\MSVC\14.30.30705\include\ostream(403): note: while compiling class template member function 'std::basic_ostream<char,std::char_traits<char>> &std::basic_ostream<char,std::char_traits<char>>::operator <<(double)'
shivani.cpp(42): note: see reference to function template instantiation 'std::basic_ostream<char,std::char_traits<char>> &std::basic_ostream<char,std::char_traits<char>>::operator <<(double)' being compiled
shivani.cpp(37): note: see reference to class template instantiation 'std::basic_ostream<char,std::char_traits<char>>' being compiled
Microsoft (R) Incremental Linker Version 14.30.30705.0
/out:shivani.exe
"/LIBPATH:C:\Program Files (x86)\intel\oneAPI\mpi\latest\env\..\lib\release"
"/LIBPATH:C:\Program Files (x86)\intel\oneAPI\mpi\latest\env\..\lib"
impi.lib
shivani.obj
C:\Users\karangux\Desktop>shivani.exe
Program starts : 0.229034
3.1415926535897931
N intervals 1000000 time = 0.261210
Calculated 3.1415926535897643
Difference 0.0000000000000289
N intervals 10000000 time = 0.167000
Calculated 3.1415926535897309
Difference 0.0000000000000622
N intervals 100000000 time = 1.671505
Calculated 3.1415926535904264
Difference 0.0000000000006333
N intervals 1000000000 time = 16.126087
Calculated 3.1415926535899708
Difference 0.0000000000001776
Total time : 18.236686
Could you please let us know if you further have any issues?
Thanks & Regards
Shivani
As we didn't hear back from you, could you please let us know if you further have any issues?
Thanks & Regards
Shivani
I've installed the latest release and the problem no longer happens.
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards
Shivani
