Intel® C++ Compiler
MSVC ICC instruction Exception
inteleverywhere
Could someone please point out what the problem is with the following snippet. An exception occurs in MSVC.
__m128i R0, R1;
__m128i *R0P1, *R0P2;
__m128i *R1P1, *R1P2;
char buf_chr[20] = { 'a', 'b', 'c', 'd', 'e', 'f', 'g', 'h', 'i', 'j',
'k', 'l', 'm', 'n', 'o', 'p', 'q', 'r', 's', 't'
R0 = _mm_loadu_si128((__m128i*) (buf_chr));
R1 = _mm_loadu_si128((__m128i*) (buf_int));
R0P1 = (__m128i *) (buf_chr);
R0P2 = (__m128i *) (buf_chr);
R0 = _mm_add_epi8(R0, R1);
*R0P1 = _mm_add_epi8((__m128i) *R0P1, (__m128i) *R0P2); // ---------> Exception occurs here.
Is there a way to do the addition if I have a register used as a pointer. Can de-referencing be done by using *?This question arises because the following statements pass without incident!
R0P1++;
R0P2++;
Thanks and Regards
Deepak
inteleverywhere
Please ignore the use of buf_int. That is not a problem. I have an array by that name. I forgot to paste it with the message. The problem is something else.
Reg
Deepak
inteleverywhere
No reply anybody there!!
Yang_W_Intel
What is your compilation option?
-Yang
Yang_W_Intel
Please check if the address of buf_chr is 16 bytes aligned. If not, there will be an exception.
inteleverywhere
You are right. But what if the data address is arbitrary. How can I use the*Register syntax.
Thanks very much.
Deepak
pvonkaenel
New Contributor III
If you cannot guarantee the alignment of the source address, then I think you need to perform an unaligned load before calling the vector instructions. This adds a lot of overhead, so it would be best to make sure the source is properly aligned. Otherwise you can try performing unoptimized byte operations on the data up until you reach the alignment point you need andthen switch to the vector instructions..
Peter
