I just upgraded from Mac OS X 10.5.8 to 10.6 (Snow Leopard). My Intel fortran and C++ compilers are version 10.1.
I have a code which required libstdc++ to be linked so I give library option -lstdc++ in the Makefile. Everything was fine with OS X 10.5.8 but when I upgraded to Snow Leopard the linking bombs with error message
ld: library not found for -lstdc++
(though there is such a library in /usr/lib).
Is the problem with the Mac OS, or do I need to upgrade the Intel compilers, or is it something else?
Any help would be appreciated.
Thank you,
Peter Young
Quoting - pyoung1948@gmail.com
Thank you,
Peter Young
I might be mistaken but if I remember correctly there is a command which can rebuild linker cache and regenerate symlinks -- it's called ldconfig [http://linux.die.net/man/8/ldconfig]. Might want to check it out.
Check here for Intel compiler version, and support OS/Xcode combination.
http://software.intel.com/en-us/articles/performance-tools-for-software-developers-compatibility-of-intel-compiler-for-mac-os-x-and-xcode/
Support for OSX 10.6 / Xcode 3.2 is now available for download, version 11.1.067.
