I have just migrated from Catalina to Big Sur and I have issues when compiling a simple C++ code with Intel icpc compiler (version 2020 Update 4).
With brew's GNU version g++-4.9, it doesn't work also but compiles fine with brew's g++-6 and g++-10 even if some warning could produce wrong results in the codes.
Before the Big Sure update, I had no problems with icpc on Catalina.
For intel, I thought that installing CTL (Command Tools line) version 11 would be sufficient but this is not the case : indeed, it is misssing the package Headers .pkg in CTL version 11 : how can I do without these Headers now ?
For the instant, I get these errors :
icpc -std=c++11 -O3 -xHost -qopenmp -Wall -c -I/opt/intel/compilers_and_libraries_2020.4.301/mac/mkl/include -I/Library/Developer/CommandLineTools/usr/include/c++/v1 -mkl=parallel main.cpp -o main.o
In file included from /Library/Developer/CommandLineTools/usr/include/c++/v1/math.h(311),
from /opt/intel/compilers_and_libraries_2020.4.301/mac/compiler/include/math.h(177),
from /Library/Developer/CommandLineTools/usr/include/c++/v1/cmath(304),
from TSAF.h(1),
from main.cpp(1):
/Library/Developer/CommandLineTools/usr/include/c++/v1/type_traits(903 error: type name is not allowed
__is_function(_Tp)
from TSAF.h(1),
from main.cpp(1):
/Library/Developer/CommandLineTools/usr/include/c++/v1/type_traits(903 error: identifier "__is_function" is undefined
__is_function(_Tp)
In file included from TSAF.h(2),
from main.cpp(1):
__is_function(_Tp)
detected during:
instantiation of class "std::__1::is_function<_Tp> [with _Tp=long long ****************************************************************************************************]" at line 1360
instantiation of class "std::__1::__decay<_Up, true> [with _Up=long long ****************************************************************************************************]" at line 1373
instantiation of class "std::__1::decay<_Tp> [with _Tp=long long ****************************************************************************************************]" at line 2119
instantiation of class "std::__1::common_type<_Tp, _Up> [with _Tp=long long ****************************************************************************************************, _Up=long long ****************************************************************************************************]" at line 2118
instantiation of class "std::__1::common_type<_Tp, _Up> [with _Tp=long long ***************************************************************************************************, _Up=long long ***************************************************************************************************]" at line 2118
[ 97 instantiation contexts not shown ]
instantiation of class "std::__1::common_type<_Tp, _Up> [with _Tp=long long *, _Up=long long *]" at line 2118
instantiation of class "std::__1::common_type<_Tp, _Up> [with _Tp=long long, _Up=long long]" at line 874 of "/Library/Developer/CommandLineTools/usr/include/c++/v1/chrono"
instantiation of class "std::__1::common_type<std::__1::chrono::duration<_Rep1, _Period1>, std::__1::chrono::duration<_Rep2, _Period2>> [with _Rep1=long long, _Period1=std::__1::micro, _Rep2=long long, _Period2=std::__1::micro]" at line 2112
instantiation of class "std::__1::common_type<_Tp> [with _Tp=std::__1::chrono::duration<long long, std::__1::micro>]" at line 1101 of "/Library/Developer/CommandLineTools/usr/include/c++/v1/chrono"
instantiation of class "std::__1::chrono::duration<_Rep, _Period> [with _Rep=long long, _Period=std::__1::micro]" at line 1575 of "/Library/Developer/CommandLineTools/usr/include/c++/v1/chrono"
from main.cpp(1):
__is_function(_Tp)
If someone could give me any track/clue in this issue of Intel compilation.
Why the Headers .pkg doesn't appear anymore with Command Tool Lines of last Package for Big Sur (version released the 14th December 2020) ?
How could I circumevent this issue ?
Any help is welcome
Thanks for reaching out to us!
As your having issue with macOS, we are escalating this thread to the concerned internal team who will further guide you.
Have a Good day.
Thanks & Regards
Goutham
IPSXE2020 Update 4 doesn't support Big Sur. You can see from
However, Intel C++ compiler in OneAPI HPC toolkit supports it. You can download from
https://software.intel.com/content/www/us/en/develop/tools/oneapi/hpc-toolkit.html
Please use oneAPI HPC toolkit. We are closing this thread. If you have any other issues, please open a new thread.
