Intel® C++ Compiler
MacOSX 10.9 support and Intel® C++ Composer XE 2013.1.119
Ihor_P_
Hello.
I have purchased Intel® C++ Composer XE 2013.1.119 in use but need to upgrade to MacOSX 10.9
So I have two questions:
1. Intel® C++ Composer XE 2013 SP1 says "MacOSX 10.9 support was added". What does this mean. Does this mean I will be not able to build with old version at all under MacOSX 10.9
2. I have some core written on Objective-C. This means that during compilation and linking I need another compiler (e.g. GCC) besides Intel Compiler. Will I be able to do this on MacOSX 10.9 when using Intel® C++ Composer XE 2013.1.119 ?
Andrey_B_Intel2
Hi Ihor,
Good choice! :-)
This compiler release supports two MacOS versions: 10.8 and 10.9. You can run the compiler on any of these. Your programs compiled with the compiler can run on older MacOS versions as well.
Yes, you need another compiler installed for Obj-C. You should install "command line tools" from XCode (see this article for details) that makes both "clang" and "gcc" compilers available in command line mode. I recommend to use "clang" to compile parts of your application written in Obj-C/C++.
Yours,
Andrey
Ihor_P_
My initial question was : will I be able to use Intel® C++ Composer XE 2013.1.119 on MacOSX 10.9 without any notable issues? What issues can appear?
Andrey_B_Intel2
Ihor, sorry for not answering before -- somehow I missed your reply. :-(
Composer XE 2013 SP1 Update 1 is the first version that supports MacOS X 10.9. See there for details: http://software.intel.com/en-us/forums/topic/486782
There are no issues I'm aware of.
Yours,
Andrey
