I'm planning on adding OpenMP SIMD pragmas to a project of mine, but I don't really need the full OpenMP; the -openmp-simd option is perfect for me.
The problem is that _OPENMP is (correctly) only defined for full OpenMP; when only -openmp-simd is used there doesn't seem to be any way to detect that the compiler supports it. It would be nice if there were a macro (_OPENMP_SIMD seems logical) to tell if omp simd pragmas are supported. I'd love to be able to do something like
#if (defined(_OPENMP) && (_OPENMP >= 201307L)) || (defined(_OPENMP_SIMD) && (_OPENMP_SIMD >= 201307L)) #pragma omp simd ... #endif
I'd probably wrap it up in a macro, but that's beside the point. As it stands the best I can do is pass something like -DOPENMP_SIMD from the build system, which isn't terrible, but it would be nice to have something a bit more standard so the code is easier to copy around across projects.
FWIW, gcc doesn't have anything for -fopenmp-simd either, but I figured I'd start with ICC since that's where the idea for -fopenmp-simd originated.
I have raised a feature request for the same. Will keep you posted when I hear back from the development team on this.
I filed GCC bug #80502 about this issue. Assuming they make the requested change, it would be great if ICC and GCC could use the same macro name…
Yes, I'm doing that. in addition to checking _OPENMP_SIMD (and living in hope), I'm checking _OPENMP, and allowing people to define a project-specific macro (SIMDE_ENABLE_OPENMP) to force the issue. Now that GCC 7 is out I'll try find someone to poke about that patch…
