Intel® C++ Compiler
Memory leak: Temporary std::set<std::string> is not deleted.
Bastian_B_
The following program:
#include <set>
#include <iostream>
std::set<std::string> Foo() {
  std::set<std::string> ret;
  ret.insert("test");
  return ret;
int main(int argc, char** argv) {
  while (true) {
    for(auto& s : Foo()) {
      // do nothing.
  return 0;
Leaks memory and causes my system to swap after a few seconds. This is on Linux x86_64, ICC Version 17.0.1, GCC Version 6.3.0. I compile like this:
icpc -o test test.C
Compiling the same program with g++ does not show this leak. Any ideas? Is there a bug in the compiler?
Judith_W_Intel
This is a known defect with temporaries and range based for loops in 17.0 update 1.
It is fixed in the soon to be release update 2.
Sorry for the inconvenience.
See this post for a detailed discussion of the bug:
https://software.intel.com/en-us/forums/intel-c-compiler/topic/705086
Judy
Bastian_B_
The bug goes away in this version:
#include <set>
#include <iostream>
  ret.insert("test");
  return ret;
  while (true) {
    std::set<std::string> foo = Foo();
    for(auto& s : foo) {
      // do nothing.
  return 0;
i.e. when first storing the result of Foo() in a temporary.
Nikolas_Z_
Bug confirmed!
I wish someone from Intel could look into this and check.
The same happens when using a std::vector<std::string> instead of std::set<std::string>. Same sympton: when bining to a local variable before the range-based for loop, there is no issue, otherwise it leaks.
Judith_W_Intel
Judy
Nikolas_Z_
Thanks a lot Judy!
Bastian_B_
Thank you Judy, we have applied a workaround along the lines of the second code snippet I posted and are looking forward to 17.0. Update 2.
SergeyKostrov
Valued Contributor II
>>... >>I compile like this: >> >>icpc -o test test.C There are compilation errors if option -std=c++11 is not used. >>.. .>>Leaks memory and causes my system to swap after a few seconds. I couldn't reproduce the problem. I'll provide more technical details on a Linux system and version of Intel C++ compiler.
SergeyKostrov
>>I couldn't reproduce the problem... Correction. Memory leaks confirmed for version 17.0.1 Update 1: ... C++ Language Standard version: 199711L Intel C++ compiler Build Date: 20161005 ...
SergeyKostrov
Older versions of Intel C++ compilers, for example 16.0.3, passed the test: [guest@... WorkTest]$ icpc test01.c -o test01.out C++ Language Standard version: 199711L Intel C++ compiler Build Date: 20160415 test01.c(131): error #303: explicit type is missing ("int" assumed) for( auto& s : Foo() ) ^ test01.c(131): error: reference variable "s" requires an initializer for( auto& s : Foo() ) ^ test01.c(131): error: expected a ";" for( auto& s : Foo() ) ^ test01.c(131): error: expected an expression for( auto& s : Foo() ) ^ test01.c(131): error: expected a ";" for( auto& s : Foo() ) ^ compilation aborted for test01.c (code 2) [guest@... WorkTest]$ [guest@... WorkTest]$ icpc -std=c++11 test01.c -o test01.out C++ Language Standard version: 201103L Intel C++ compiler Build Date: 20160415 [guest@... WorkTest]$ [guest@... WorkTest]$ date Tue Feb 21 11:19:49 PST 2017 [guest@... WorkTest]$ [[guest@... WorkTest]$ ./test01.out ^C [guest@... WorkTest]$ [guest@... WorkTest]$ date Tue Feb 21 11:21:01 PST 2017 No any memory leaks.
Bastian_B_
Thanks for the additional tests Sergey, I believe with 17.0 Update 1 and GCC 6.3.0 -std=c++11 is default so I didn't add it in the flags.
