Intel® C++ Compiler
Memory leak?
velvia
I have a C++ application which is coded this way:
  • The main program does not need much memory (just a few variables). But this main program runs a loop in which we call a function.
  • This function needs about 140 MB of memory to run. The memory is allocated in the function and then released (using RAII).
When I run this program overnight on OSX, here is the data I get from "Activity Monitor", or "top" in terms of memory consumption
  • After the first loop, the program takes 150 MB of memory
  • After 68 loops, the program takes 220 MB of memory
  • After 394 loops, the program takes 480 MB of memory
So it seems that the function, which allocates and deallocated 140 MB of memory, "leaks" about 1 MB each time it is called. In this function, the allocated objects are:
  • My own version of std::vector which I call il::Vector, il::Matrix, il::Tensor. I have used these class in other codes and they seem fine.
  • A class that calls Pardiso from the MKL. Using RAII, I take care of properly deallocating Pardiso memory before I destroy the class (using the phase -1).
I have used Pointer Checker from Intel (on a Linux workstation) and Address Sanitizer from Clang on the program (with smaller inputs though) and they don't detect anything. I don't really know what to do. Is there a way memory fragmentation is responsible for this?
velvia
I think that I have found the culprit: the MKL. I use Pardiso, and the following example leaks very slowly: about 0.1 MB every 13 seconds which leads to 280 MB overnight. These are the numbers I get from my simulation.
If you want to give it a try, you can compile it with:
icpc -std=c++11 pardiso-leak.cpp -o main -lmkl_intel_lp64 -lmkl_core -lmkl_intel_thread -liomp5 -ldl -lpthread -lm
The short version of the code that leaks memory is:
#include <iostream>
#include <vector>
#include "mkl_pardiso.h"
#include "mkl_types.h"
int main (int argc, char const *argv[])
  const auto n = std::size_t{1000};
  auto m = MKL_INT{n * n};
  auto values = std::vector<double>();
  auto column = std::vector<MKL_INT>();
  auto row = std::vector<MKL_INT>();
  row.push_back(1);
  for(std::size_t j = 0; j < n; ++j) {
    column.push_back(j + 1);
    values.push_back(1.0);
    column.push_back(j + n + 1);
    values.push_back(0.1);
    row.push_back(column.size() + 1);
  for(std::size_t i = 1; i < n - 1; ++i) {
      column.push_back(n * i + j - n + 1);
      column.push_back(n * i + j + 1);
      column.push_back(n * i + j + n + 1);
    column.push_back((n - 1) * n + j - n + 1);
    column.push_back((n - 1) * n + j + 1);
  auto y = std::vector<double>(m, 1.0);
  auto x = std::vector<double>(m, 0.0);
  auto pardiso_nrhs = MKL_INT{1};
  auto pardiso_max_fact = MKL_INT{1};
  auto pardiso_mnum = MKL_INT{1};
  auto pardiso_mtype = MKL_INT{11};
  auto pardiso_msglvl = MKL_INT{0};
  MKL_INT pardiso_iparm[64];
  for (int i = 0; i < 64; ++i) {
    pardiso_iparm = 0;
  pardiso_iparm[0] = 1;
  pardiso_iparm[1] = 2;
  pardiso_iparm[3] = 0;
  pardiso_iparm[4] = 0;
  pardiso_iparm[5] = 0;
  pardiso_iparm[7] = 0;
  pardiso_iparm[8] = 0;
  pardiso_iparm[9] = 13;
  pardiso_iparm[10] = 1;
  pardiso_iparm[11] = 0;
  pardiso_iparm[12] = 1;
  pardiso_iparm[17] = -1;
  pardiso_iparm[18] = 0;
  pardiso_iparm[20] = 0;
  pardiso_iparm[23] = 1;
  pardiso_iparm[24] = 0;
  pardiso_iparm[26] = 0;
  pardiso_iparm[27] = 0;
  pardiso_iparm[30] = 0;
  pardiso_iparm[31] = 0;
  pardiso_iparm[32] = 0;
  pardiso_iparm[33] = 0;
  pardiso_iparm[34] = 0;
  pardiso_iparm[59] = 0;
  pardiso_iparm[60] = 0;
  pardiso_iparm[61] = 0;
  pardiso_iparm[62] = 0;
  pardiso_iparm[63] = 0;
  void* pardiso_pt[64];
    pardiso_pt = nullptr;
  auto error = MKL_INT{0};
  auto phase = MKL_INT{11};
  MKL_INT i_dummy;
  double d_dummy;
  PARDISO(pardiso_pt, &pardiso_max_fact, &pardiso_mnum, &pardiso_mtype,
          &phase, &m, values.data(), row.data(), column.data(), &i_dummy,
          &pardiso_nrhs, pardiso_iparm, &pardiso_msglvl, &d_dummy,
          &d_dummy, &error);
  phase = 22;
          &d_dummy, &error);
  phase = 33;
  for(size_t i = 0; i < 10000; ++i) {
    std::cout << "i = " << i << std::endl;
            &pardiso_nrhs, pardiso_iparm, &pardiso_msglvl, y.data(),
            x.data(), &error);
  phase = -1;
          &d_dummy, &error);
  return 0;
KitturGanesh
I'll let the MKL team know on this issue with memory leak, appreciate much.
_Kittur
Ying_H_Intel
Hi velvia
velvia
fayard@Speed:Fast$ icc --version
icc (ICC) 15.0.2 20150121
Copyright (C) 1985-2015 Intel Corporation.  All rights reserved.
I use the MKL that ships with this version of the compiler.
Ying_H_Intel
Hi velvia
We try run the code on linux  and windows,  but don’t see any memory leaks if call MKL_FREE_Buffers.  We run our own test that calculated size of allocated memory.  And on windows,  I try the Intel Amplifer Xe also and saw there are memory leak in the STL  vector,  (auto values = std::vector<double>();
Could you rerun your test with some vector memory release  and mkl_free_buffers()?
For example,
std::vector<double>().swap(values);
return 0;
 to verify you result?  If it will positive,  I will move to Mac Os based machine.
Ying
Ying_H_Intel
Hi Velvia,
1) No,  I haven't seen the memory usage increase.
I run the small code (your original code, no mkl_free_buffers) on one Mac OS.  I attach two screencopy ( I=400,  I=  for your reference. )
1.1.  Are you call the code in parallel region.  Anyway, you can add  mkl_free_buffers() after the function call and see if there is any change.
2) I'm not sure, but from Inspector XE,  It show there is memory leak at line 33
row.push_back(1);
  line 33.   values.push_back(1.0);
I attach the screen shot for your reference.
Ying
Ying_H_Intel
Ying_H_Intel
