Intel® C++ Compiler
7838 Discussions
Microsoft 'libcpmt.lib' and Intel 'libmmt.lib' locale-related conflicts for static Qt builds using ICC on Windows
sav
Hello everyone,
For Qt builds using ICC on Windows got error:
        cd planets-qml\ && ( <span class="code-keyword">if</span> not exist Makefile c:\libQT-5.11-dev\build\qtbase\bin\qmake.exe -o Makefile c:\libQT-5.11-dev\build\qt3d\examples\qt3d\planets-qml\planets-qml.pro ) && <span class="code-quote">"C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\bin\HostX64\x64\nmake.exe"</span> -f Makefile
Microsoft (R) Program Maintenance Utility Version 14.11.25547.0
Copyright (C) Microsoft Corporation.  All rights reserved.
        <span class="code-quote">"C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\bin\HostX64\x64\nmake.exe"</span> -f Makefile.Release
        echo 1 /* CREATEPROCESS_MANIFEST_RESOURCE_ID */ 24 /* RT_MANIFEST */ <span class="code-quote">"release\\planets-qml.exe.embed.manifest"</span>>release\planets-qml.exe_manifest.rc
        <span class="code-keyword">if</span> not exist release\planets-qml.exe <span class="code-keyword">if</span> exist release\planets-qml.exe.embed.manifest del release\planets-qml.exe.embed.manifest
        <span class="code-keyword">if</span> exist release\planets-qml.exe.embed.manifest copy /Y release\planets-qml.exe.embed.manifest release\planets-qml.exe_manifest.bak
        xilink /NOLOGO /SUBSYSTEM:WINDOWS <span class="code-quote">"/MANIFESTDEPENDENCY:type='win32' name='Microsoft.Windows.Common-Controls' version='6.0.0.0' publicKeyToken='6595b64144ccf1df' language='*' processorArchitecture='*'"</span> /MANIFEST /MANIFESTFILE:release\planets-qml.exe.embed.manifest /OUT:release\planets-qml.exe @C:\Users\test\AppData\Local\Temp\nm3C50.tmp
libcpmt.lib(locale.obj) : error LNK2005: ldexpf already defined in libmmt.lib(ldexpf_iface_c99.obj)
libcpmt.lib(wlocale.obj) : error LNK2005: ldexpf already defined in libmmt.lib(ldexpf_iface_c99.obj)
   Creating library release\planets-qml.lib and object release\planets-qml.exp
release\planets-qml.exe : fatal error LNK1169: one or more multiply defined symbols found
NMAKE : fatal error U1077: '<span class="code-quote">"C:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\bin\intel64\xilink.EXE"</span>' : <span class="code-keyword">return</span> code '0x491'
Stop.
NMAKE : fatal error U1077: '<span class="code-quote">"C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.11.25503\bin\HostX64\x64\nmake.exe"</span>' : <span class="code-keyword">return</span> code '0x2'
Stop.
NMAKE : fatal error U1077: 'cd' : <span class="code-keyword">return</span> code '0x2'
Stop.
Stop.
Stop.
Stop.
during planets-qml build, which relate to Microsoft libcpmt.lib and Intel libmmt.lib libraries.
Reproduced for:
  • static Qt builds using Windows ICC,
not reproduced for:
  • shared Qt builds using Windows ICC,
  • static Qt builds using mingw-w64 and MSVC.
It was registered on Qt bugtracker as QTBUG-64898, and Qt Developers believe it not Qt bug. And since error not reproduce for MSVC, it presumably is ICC bug.
Best,
Alexander
Jingwei_Z_Intel
Microsoft implements ldexpf in object files that has nothing to do with math library. We have asked Microsoft to remove such cases. Meanwhile, you can try to add "/FORCE:MULTIPLE" to your linker command to resolve the conflict.
sav
Thank you for a tip, Jingwei. Though trying to avoid "/FORCE:MULTIPLE" in build commands and prefer to disable failed builds.
Can you share a link to related ticket on Devcommunity or somewhere else, so it would be possible to track this issue directly?
Jingwei_Z_Intel
Based on what I have heard, Microsoft would fix the issue in the next Windows 10 release. I don't have a ticket number for this.
Jingwei
sav
Any news on this? Since for environment:
  • Windows 10 x64 10.0.17134.1,
  • ICC 2018 Update 3,
  • MSVC 2017 15.7.3,
  • Windows SDK 10.0.17134.12,
errors still reproduced.
A missing ticket number would be appreciated. Otherwise, there is not much to talk about with the Developers of MSVC.
Best,
Alexander
roberto_g_2
Issue still there...  December 2020
