Recently I upgraded Intel Composer XE 2013 to Intel Composer XE 2015. Then I found that 2015 linker unable to find libicaio.lib (asynchronous I/O library) for 64 bit version. I checked the installation directory. libicaio.lib only exist for 32 bit version. There is no 64bit version. However the both libraries exist in 2013 version.
C:\Program Files (x86)\Intel\Composer XE 2015\compiler\lib\ia32\libicaio.lib
C:\Program Files (x86)\Intel\Composer XE 2015\compiler\lib\intel64\ No such file in this directory.
Where can I find 64bit asynchronous I/O library in 2015?
Hi Shuji,
I received a very similarly worded issue in Intel(R) Premier Support - perhaps a coworker of yours. This does seem to be missing from the initial 2015 product version, but I believe this should get back in the package for the upcoming update 1, although I'll need to confirm that once that package is available. I do have a copy of the library I can send via Intel(R) Premier Support if you need it, although if this other issue I received was from an associate, you should be able to get it from him as well.
For your referral, the tracking ID for this issue is DPD200362494.
The library should now be back as expected in the Intel(R) Parallel Studio XE 2015 update 2 packages.
