I'm having some issues with missing wide string crt functions when compiling with /Qstd=C++17 in x64 release builds. I'm getting errors like
ipo_2060819obj3.obj : : error LNK2019: unresolved external symbol wmemcmp referenced in function main
It works fine with narrow strings or when targetting C++14. I'm using the latest Intel Compiler 2019 update 3 and Visual Studio 2017 15.9.11. I've attached a minimal example of the problem.
Thanks for your help.
Steven.
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
It could be that VS2017 15.9.11 hasn't been supported by ICL 19.0 Update 3. Does it work if you use older VS2017 (ex:15.8)?
I think I first spotted the problem with 15.9.4 and then upgraded to the latest to see if that helped.
I've also run into the same issue. A complex project builds just fine with MSVC in Debug+Release. Builds fine in Debug with Intel Compiler v19.0.
Fails in Release with Intel Compiler v19.0:
Severity Code Description Project File Line Suppression State
Error LNK2019 unresolved external symbol wmemcmp referenced in function "public: class fmt::v6::basic_format_arg<class fmt::v6::basic_format_context<class std::back_insert_iterator<class fmt::v6::internal::buffer<wchar_t> >,wchar_t> > __cdecl fmt::v6::basic_format_context<class std::back_insert_iterator<class fmt::v6::internal::buffer<wchar_t> >,wchar_t>::arg(class fmt::v6::basic_string_view<wchar_t>)" (?arg@?$basic_format_context@V?$back_insert_iterator@V?$buffer@_W@internal@v6@fmt@@@std@@_W@v6@fmt@@QEAA?AV?$basic_format_arg@V?$basic_format_context@V?$back_insert_iterator@V?$buffer@_W@internal@v6@fmt@@@std@@_W@v6@fmt@@@23@V?$basic_string_view@_W@23@@Z) FlatbufCppLib FlatbufCppLib\ipo_3661235obj3.obj : 1
I ended up "solving" the problem by migrating everything from wstring to string. Then it compiled in Release mode (it was only compiling in Debug mode before that).
I think it's only an issue if two wstring objects are compared with an "==" sign.
For any existing functions that required wstring, I used the following.
#pragma once #include <string> #include <filesystem> using namespace std; inline wstring StringToWString(const string &s) { wstring wsTmp(s.begin(), s.end()); return wsTmp; } inline string WStringToString(const wstring &s) { string wsTmp(s.begin(), s.end()); return wsTmp; }
