LAST
Sorry,sorry,sorry
stupid I forgot to install the lib IA32
works very well
Hi
I have make install default gcc version 4.3.2 DEBIAN 5 (64 package)
l_cproc_p_11.0.081_intel64
result
Missing critical pre-requisite missing system commands 32-bit libraries not found
I have also download l_cproc_p_11.0.069_intel64 for make test with
result
I have also download l_cproc_p_11.0.069_ia32 for make test with
result
I have have build new source gcc 4.3.3 compiler
./configure -v --enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr --enable-shared --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --enable-nls --with-gxx-include-dir=/usr/include/c++/4.3 --program-suffix=-4.3.3 --enable-clocale=gnu --enable-libstdcxx-debug --enable-objc-gc --enable-mpfr --enable-cld --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu
result
Curious with DEBIAN 5 (32 package)
l_cproc_p_11.0.069_ia32 working very well
In Debian 64 package all programs required are installed exatly same Debian package 32 .
I must move some lib specific repertory ??
g++-4.3.3 -print-search-dirs
installs: /usr/lib/gcc/x86_64-linux-gnu/4.3.3/
programmes: =/usr/lib/gcc/x86_64-linux-gnu/4.3.3/:/usr/lib/gcc/x86_64-linux-gnu/4.3.3/:/usr/lib/gcc/x86_64-linux-gnu/:/usr/lib/gcc/x86_64-linux-gnu/4.3.3/:/usr/lib/gcc/x86_64-linux-gnu/:/usr/libexec/gcc/x86_64-linux-gnu/4.3.3/:/usr/libexec/gcc/x86_64-linux-gnu/:/usr/lib/gcc/x86_64-linux-gnu/4.3.3/:/usr/lib/gcc/x86_64-linux-gnu/:/usr/lib/gcc/x86_64-linux-gnu/4.3.3/../../../../x86_64-linux-gnu/bin/x86_64-linux-gnu/4.3.3/:/usr/lib/gcc/x86_64-linux-gnu/4.3.3/../../../../x86_64-linux-gnu/bin/
libraries: =/usr/lib/gcc/x86_64-linux-gnu/4.3.3/:/usr/lib/gcc/x86_64-linux-gnu/4.3.3/:/usr/lib/gcc/x86_64-linux-gnu/4.3.3/../../../../x86_64-linux-gnu/lib/x86_64-linux-gnu/4.3.3/:/usr/lib/gcc/x86_64-linux-gnu/4.3.3/../../../../x86_64-linux-gnu/lib/../lib64/:/usr/lib/gcc/x86_64-linux-gnu/4.3.3/../../../x86_64-linux-gnu/4.3.3/:/usr/lib/gcc/x86_64-linux-gnu/4.3.3/../../../../lib64/:/lib/x86_64-linux-gnu/4.3.3/:/lib/../lib64/:/usr/lib/x86_64-linux-gnu/4.3.3/:/usr/lib/../lib64/:/usr/lib/gcc/x86_64-linux-gnu/4.3.3/../../../../x86_64-linux-gnu/lib/:/usr/lib/gcc/x86_64-linux-gnu/4.3.3/../../../:/lib/:/usr/lib/
Hi have also change 5 with 4 file /etc/debian_version
wrong result same.
Also i think that to use old Debian 4 (64 package) probably result exatly same.
Howto make to install 64 Compiler ?? Bi arch Problem ??
Best regards
LAST
Sorry,sorry,sorry
works very well
Sorry,sorry,sorry
works very well
Hi
result
result
result
result
wrong result same.
Best regards
LAST
Sorry,sorry,sorry
works very well
Hi bustaf,
Thank you for sharing your experience with all the people in this forum.
We have an article on installing Intel compiler on Ubuntu, which may be helpful to users who work on Ubuntu or Debian. Read the article here.
Thanks,Thank you for sharing your experience with all the people in this forum.
Feilong
Quoting - Feilong H. (Intel)
Hi bustaf,
Feilong
Hi Feilong,
Thank you
Better now that various users of Linux community without distribution imposed
can take benefit with ICC compiler, and in general used or discover the last technical evolutions C/C++ language. (Openmp,Tbb,mpich2 ,and other new types programing sides etc..)
Best regards
