Intel® C++ Compiler
7956 Discussions
Missing several Intrinsics for Miscellaneous Operations in User and Reference Guide for C++
Nathan_Weeks
In the User and Reference Guide for the Intel® C++ Compiler 15.0, the "Intrinsics for Miscellaneous Operations" (https://software.intel.com/en-us/node/524118) is missing the following intrinsics:
  • _mm256_set_epi8
  • _mm256_set_epi16
  • _mm256_set_epi64x
  • _mm256_setr_epi8
  • _mm256_setr_epi16
  • _mm256_setr_epi64x
  • _mm256_set1_epi8
  • _mm256_set1_epi16
  • _mm256_set1_epi64x
Nathan Weeks
Systems Analyst
Iowa State University -- Department of Mathematics
http://weeks.public.iastate.edu/
KitturGanesh
Thanks Nathan, yet again I'll escalate this to the doc team - appreciate much.
_Kittur
Nathan_Weeks
Hi Kittur,
I noticed additional documentation discrepancies for the instructions corresponding to AVX Miscellaneous Intrinsics in the Intel® 64 and IA-32 Architectures Software Developer’s Manual:
1. Vol. 2B 4-513 (PDF p. 1609): In the "Intel C/C++ Compiler Intrinsic Equivalent" section, INSERTF128 should be VINSERTF128.
2. Vol. 2A 3-453 (PDF p. 943): In the "Intel C/C++ Compiler Intrinsic Equivalent" section,
    LDDQU: __m256i _mm256_lddqu_si256 (__m256i * p);
should be
    VLDDQU: __m256i _mm256_lddqu_si256 (__m256i * p);
3. Vol. 2A 3-547 (PDF p. 1037): The "Intel C/C++ Compiler Intrinsic Equivalent" section should contain:
    VMOVMSKPD:     _mm256_movemask_pd(__m256d a)
Nathan Weeks
Systems Analyst
KitturGanesh
Thanks Nathan. I've updated the issue I'd filed with this new issue you noticed as well, with our doc team. Again, appreciate much for catching this.
_Regards, Kittur
