It looks like ICC is missing support for the retuns_nonnull attribute (tested up to 19.0.1), which has been present in GCC since 4.9. Here is a quick test case:
#include <stdio.h> static const char* foo = "bar\n"; #if defined(__GNUC__) && ((__GNUC__ > 4) || ((__GNUC__ == 4) && (__GNUC_MINOR__ >= 9))) __attribute__((__returns_nonnull__)) #endif static const char* get_string(void) { return foo; } int main(void) { const char* s = get_string(); if (s != NULL) fputs(s, stdout); else fputs("This shouldn't happen\n", stdout); return 0; }
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
You meant the warning 1292?
vahoang@orcsle147:/tmp$ icc t8.c
t8.c(6): warning #1292: unknown attribute "__returns_nonnull__"
vahoang@orcsle147:/tmp$ ./a.out
bar
Yes. If __GNUC__/__GNUC_MINOR__ are defined to ≥ 4.9 it should be supported or silently ignored. I'd obviously prefer the former, but it definitely shouldn't generate a diagnostic. At least not where it does; a diagnostic in main() about checking for null could be nice, but I think in GCC this is mostly used for optimization. For example, with:
#include <stdio.h> #if defined(__GNUC__) && ((__GNUC__ > 4) || ((__GNUC__ == 4) && (__GNUC_MINOR__ >= 9))) __attribute__((__returns_nonnull__)) #endif const char* get_string(void); int main(void) { const char* s = get_string(); if (s != NULL) fputs(s, stdout); else fputs("This shouldn't happen\n", stdout); return 0; }
GCC can elide the checks. At -O3, GCC generates
0: 48 83 ec 08 sub $0x8,%rsp 4: e8 00 00 00 00 callq 9 <main+0x9> 9: 48 8b 35 00 00 00 00 mov 0x0(%rip),%rsi # 10 <main+0x10> 10: 48 89 c7 mov %rax,%rdi 13: e8 00 00 00 00 callq 18 <main+0x18> 18: 31 c0 xor %eax,%eax 1a: 48 83 c4 08 add $0x8,%rsp 1e: c3 retq
But if you remove the attribute it generates:
0: 48 83 ec 08 sub $0x8,%rsp 4: e8 00 00 00 00 callq 9 <main+0x9> 9: 48 85 c0 test %rax,%rax c: 74 16 je 24 <main+0x24> e: 48 8b 35 00 00 00 00 mov 0x0(%rip),%rsi # 15 <main+0x15> 15: 48 89 c7 mov %rax,%rdi 18: e8 00 00 00 00 callq 1d <main+0x1d> 1d: 31 c0 xor %eax,%eax 1f: 48 83 c4 08 add $0x8,%rsp 23: c3 retq 24: ba 16 00 00 00 mov $0x16,%edx 29: be 01 00 00 00 mov $0x1,%esi 2e: bf 00 00 00 00 mov $0x0,%edi 33: 48 8b 0d 00 00 00 00 mov 0x0(%rip),%rcx # 3a <main+0x3a> 3a: e8 00 00 00 00 callq 3f <main+0x3f> 3f: eb dc jmp 1d <main+0x1d>
Thanks, will report to our Front-end team.
