Is there anyway to see the assembly output corresponding to a source file? I know that with Vtune the mixed by source option can show the resulting assembly instructions beneath the original source code. However, it seems awkard to have to profile the code just to see the output of the compiler. I am using the Intel C++ compiler integrated into the Microsoft Visual Studio 2005 IDE.
You do not need to profile the binary to get that info. Start vTune, select open file and open your executable. Then double click on your function and once you let vtune know where your file source is is your source then it will display the assembly beneath the source file (if you select that view).
Hope it helps.
Nick
You could set one of the options to generate a .asm file, showing source line numbers in the comment field.
