Ok, so I have vtune, the thread profiler, and the intel compiler. The compiler seems to work with VS2005, but vtune seems completely non-functional because I have an Athalon processor. Is there a way to configure thisfor different processors?
Also, I just finished installing it onto my laptop, which does have an intel processor, only to find out that it doesn't work with Visual C++ express edition.
I have literally wasted the day installing software, and nothing works, so I am a bit frustrated. Do I have any options here, or what?
-Kevin
I don't know why VS2005 express wouldn't work on a laptop; it was OK on my 4 year old Centrino. It's a bit more complicated to install than VS2005 standard; there are separate Microsoft web pages explaining it. The 32- (and 64-bit, if you want it) compilers are separate downloads, and the Microsoft C++ must be installed before any Intel compiler can be installed. 2005 Express has the documented limitation that no non-Microsoft compiler is allowed to work with it, except by command line.
Well, VS Express worked fine, it was VTune that didn't work with it. I downloaded VS Std last night, so I guess I will spend the day un-installing yesterday's venture and re-installing. I am sure glad I didn't have to pay for all of this stuff -- I would be even more upset if that were the case.
Anyway, the compiler works fine on my AMD system, it is just the VTUNE stuff that doesn't. I guess I thought if there were dependancies, it would be the other way around...
Thanks for the response. At least I know now I have to un-install all the intel stuff as well to make it work right.
One thing that did cross my mind --if none of this stuff works with an AMD processor, why didn't the installer tell me that I was about to waste hours of time installing it onto a machine it wouldn't work on?
-Kevin
