Hi, surprisingly the following code generates an error:
#include <utility>
struct A
A & operator=(A &&);
A & operator=(A const &) = delete;
struct B
A a;
int main()
B b1, b2;
b1 = std::move(b2); // calls B's implicitly-declared move assignment operator which should call A's move assignment operator
return 0;
The error report is: function "A::operator=(const A &)" (declared at line 5) cannot be referenced -- it is a deleted function
The compiler wants to call A's copy assignment operator. I think this is not correct.
What do you think?
Do previous posts on this question, e.g. https://software.intel.com/en-us/forums/topic/496266 shed any light? You would need to report your specific g++ or MSVC version and options used to go anywhere with this.
My reply was accepted but didn't show up. Sorry if this duplicates.
I don't want to repeat previous discussions, e.g.
You didn't say whether you have an MSVC or g++ which supports your usage.
Hi Tim,
yes, the post you mention does shed light.
I use MSVC2013 and the November CTP compiler. This combination implicitly generates the move assignment operator.
Switching to the Intel compiler with "CTP_Nov2013" base platform toolset does not work, but now I know that this is intentional.
The hidden compiler switch is the solution.
Thank you, Tim.
