Intel® C++ Compiler
7931 Discussions
Moving from icc to icx: known but unsupported action 'nopage' for '#pragma section' -
roberto_g_2
Dear Staff,
is there any chance that "nopage" in #pragma section will be supported in the future releases?
Thank you
-Roberto
HemanthCH_Intel
Hi Roberto ,
We are looking into your query and get back to you soon.
Thanks & Regards,
Hemanth Chintala.
Viet_H_Intel
Hi Roberto,
Seems like icx supports nopage on Linux. Are you asking for Windows?
$ icpx test.cpp -fdeclspec
$ cat test.cpp
#pragma section(".data",nopage)
__declspec(allocate(".data"))
int main(){
  return 0;
C:\temp>icx test.cpp
Intel(R) oneAPI DPC++/C++ Compiler for applications running on Intel(R) 64, Version 2021.4.0 Build 20210924
Copyright (C) 1985-2021 Intel Corporation. All rights reserved.
test.cpp(1,9): warning: known but unsupported action 'nopage' for '#pragma section' - ignored [-Wignored-pragmas]
1 warning generated.
C:\temp>
roberto_g_2
Thank you for handling my question. Sure, sorry, I forgot to say that it was for Windows
A workaround is to compile the objects, and use link.exe instead of lld-link.exe, and give the option /SECTION:name,!P but this prevents from using lld-link.
-Roberto
Viet_H_Intel
Can you give us an example testcase, compile and link steps for your workaround that prevents you from using lld-link?
roberto_g_2
Sure!
-R
C:\temp>type foo.cpp
#include <iostream>
using namespace std;
#pragma section(".mysection")
__declspec(allocate(".mysection")) int x = 1;
int main(){
cout << x << endl;
return 0;
C:\temp> icx.exe /c /Qm64 foo.cpp
C:\temp> link.exe /SECTION:.mysection,R!P foo.obj
C:\temp> foo.exe
1
C:\temp> lld-link.exe /SECTION:.mysection,R!P foo.obj
lld-link: error: /section: invalid argument: R!P
Viet_H_Intel
Hi Roberto,
Thank for the test case. I've submitted a request to the compiler team. I'll keep you posted.
roberto_g_2
HemanthCH_Intel
Thank you for your feedback. We have provided your feedback to the relevant team. At this moment there is no visibility when it will be implemented and available for use. Please let me know if we can go ahead and close this case.
Thanks & Regards,
Hemanth
HemanthCH_Intel
We are closing this thread. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Hemanth
roberto_g_2
Yes please, thanks for answering!
-R
