Intel® C++ Compiler
7835 Discussions
Multiply defined symbols error when using std::tr1::regex from VS 2008 SP1
Michael_Wild
Hi all
If I try to use std::tr1::regex in more than one compilation unit I get a linker error because the static member data std::tr1::_Regex_traits::_Names gets instantiated in each of the object files since the definition of the explicit specialization is in the header.
Strangely, this works when using the Microsoft compiler. Anybody got an idea how to resolve this issue?
Michael
PS: This is with
  • Windows 7
  • Visual Studio 2008 SP1
  • Intel C++ Compiler 11.1.046
Michael_Wild
A simple example would be the following:
main.cpp:
[cpp]#include
// This function is defined in foo.cpp and also
// uses std::tr1::regex
void foo();
int main(int argc, char* argv[])
	std::tr1::regex re("^Hello World!$", std::tr1::regex::extended);
	std::tr1::regex_match("Hello World!", re);
	foo();
	return 0;
}[/cpp]
foo.cpp:
[cpp]#include
void foo()
	std::tr1::regex re("African");
	bool match = std::tr1::regex_search("European or African?", re);
}[/cpp]
JenniferJ
Yeh, I saw the issue too.
Thanks for reporting it and the testcase. I'll report it to the compiler engineering team. if there's any news, I'll let you know. At this moment, I don't know of any work-around.
Thanks again.
Jennifer
Michael_Wild
Thanks!
As a work-around (more like a cludge) I resorted to #include all the files that use into one single master-file instead of compiling them directly.
Michael
JenniferJ
this issue has been fixed in our 12.0 compiler. the initial release should contain the fix.
thanks,
Jennifer
