I am developing an encoder that has too many tight loops and mathematical operations. I am using intel compiler 11.0 and IPP for memory allocation and for memory copying. I dont use any optimization in the release, But the release build is 4 times slower in execution than the debug build. I am linking the IPP libraries as static with dispatching.
Quoting - nyryder
This is unusual. Could you share details to construct some sort of test case to try out?
Om
Quoting - nyryder
Wow that does sound strange. You mentioned that you have no optimizations enabled in the release build, so basically the debug and release builds are the same except that the debug build adds symbol generation? Could you list the actual compiler flags you're using for both builds?
Peter
Quoting - pvonkaenel
Peter
The following options are the command line arguments for the compiler for error case(release build execution time is 6 times slower than the debug build)
Release
/c /Od /Ot /Qip /D "WIN32" /D "NDEBUG" /D "_CONSOLE" /D "_UNICODE" /D "UNICODE" /EHsc /MD /GS /fp:precise /Fo"Release/" /W3 /nologo /Wp64 /Qfp-speculationoff /Qparallel /arch:SSE3
Debug
/c /Od /Ot /Qip /D "WIN32" /D "_DEBUG" /D "_CONSOLE" /D "_UNICODE" /D "UNICODE" /EHsc /RTC1 /MDd /GS /fp:precise /Fo"Debug/" /W3 /nologo /Wp64 /ZI /Qfp-speculationoff /Qparallel /arch:SSE3
I used ippGetCpuClocks() to measure the time elapsed by the encoder.
In the error case
The release build takes 3375043462 ticks (920 ms)
and the debug build takes 632293616 ticks. (169ms)
The relase build is almost 6 times slower than the Debug build.
