I am trying to compile namd(with smp) on centos 6.4 with intel 2015 for intel xeon phi , and i am getting following error:
MPIR_Thread: TLS definition in libmpi_mt.so section .tbss mismatches non-TLS definition in libmpi.so.12 section .bss could not read symbols: Bad value
attached :
- namdmic.log : compilation error log
- namd_build_smp.sh: namd compilation script
I tried this solution but then i got:
Adding file obj/psfplugin.o... OpenMP support enabled charmc> ----------- Module dependency search ------------ charmc> ----------- Module dependency search complete ------------ Adding registration for module NeighborLB Adding registration for module HybridLB Adding registration for module RefineLB Adding registration for module GreedyLB Adding registration for module CkMulticast charmc: Executing mpicxx -m64 -fPIC -D_REENTRANT -D__CHARMC__=1 -DCMK_OPTIMIZE=1 -Iinc -Isrc -Ofast -fomit-frame-pointer -fp-model fast=2 -xHost -qopenmp -mt_mpi -offload-option,mic,compiler,-vec -offload-option,mic,compiler,-restrict -U_FORTIFY_SOURCE -fno-stack-protector -fopenmp -c moduleinit6026.C -o moduleinit6026.o g++: fast=2: No such file or directory g++: unrecognized option '-qopenmp' g++: language Host not recognized g++: language Host not recognized Fatal Error by charmc in directory /home/puneet/NAMD_BUILD/NAMD_2.10_Source/Linux-x86_64-icc Command mpicxx -m64 -fPIC -D_REENTRANT -D__CHARMC__=1 -DCMK_OPTIMIZE=1 -Iinc -Isrc -Ofast -fomit-frame-pointer -fp-model fast=2 -xHost -qopenmp -mt_mpi -offload-option,mic,compiler,-vec -offload-option,mic,compiler,-restrict -U_FORTIFY_SOURCE -fno-stack-protector -fopenmp -c moduleinit6026.C -o moduleinit6026.o returned error code 1 charmc exiting... rm -f moduleinit6026.C moduleinit6026.o make: *** [namd2] Error 1
Eagerly awaiting your reply,
g++ doesn't support MPI on production Intel(r) Xeon Phi(tm). Assuming you intended to use mpiicpc, you should check your initial build configuration. If you are using a non-Intel MPI which supports MIC via mpicxx, you should say so, but support channels for that MPI are more likely to be useful.
There is advice on this posted by Intel: https://software.intel.com/en-us/articles/namd-for-intel-xeon-phi-coprocessor
Questions about Intel MPI are more likely to find experts on the HPC and Cluster forum, or, since it is about MIC, that forum might be useful.
