Intel® C++ Compiler
NaN bugs
Inge_H_
I'm having some unexpected behaviour from NaN's when swithing to the Intel C++ compiler.
#include <math.h>
int main()
  // Comparing two NaNs should result in a False
  if (NAN == NAN) return -1;
  return 0;
Comparing two NaNs should result in a False but results in a True. Any ideas what's up with this?
Inge_H_
Here is a more complete example:
// NaNTest.cpp : Defines the entry point for the console application.
#include "stdafx.h"
#include <math.h>
#include <iostream>
int _tmain(int argc, _TCHAR* argv[])
    if (NAN == NAN)
        std::cerr << "Bad NaN" << std::endl;
    else
        std::cout << "Good NaN" << std::endl;
    getchar();
    return 0;
Visual Studio 2013 compiler returns "Good NaN" while Intel C++ 14 compiler returns "Bad NaN" after running the above code.
Inge_H_
I just figured it out myself. The default floating point model is /fp:fast and must be set to /fp:strict or /fp:precise for NaN's to work properly.
