In my project, I make heavy use of the boost libraries, especially boost/dynamic_bitset. All worked fine with icc 9.0 (and several gcc version including 4.0), but when I switched to icc 9.1, I get error messages in the boost library code:
icpc bitset.cc
/usr/include/boost/dynamic_bitset/dynamic_bitset.hpp(1435): error: name followed by "::" must be a class or namespace name
const ios_base::iostate ok = ios_base::goodbit;
/usr/include/boost/dynamic_bitset/dynamic_bitset.hpp(1436): error: name followed by "::" must be a class or namespace name
ios_base::iostate err = ok;
/usr/include/boost/dynamic_bitset/dynamic_bitset.hpp(1436): error: expected a ";"
/usr/include/boost/dynamic_bitset/dynamic_bitset.hpp(1438): error: a class or namespace qualified name is required
typename basic_ostream::sentry cerberos(os);
/usr/include/boost/dynamic_bitset/dynamic_bitset.hpp(1438): error: type name is not allowed
/usr/include/boost/dynamic_bitset/dynamic_bitset.hpp(1438): error: the global scope has no "sentry"
/usr/include/boost/dynamic_bitset/dynamic_bitset.hpp(1438): error: expected a ";"
&n bsp; ^
/usr/include/boost/dynamic_bitset/dynamic_bitset.hpp(1439): error: identifier "cerberos" is undefined
if (cerberos) {
/usr/include/boost/dynamic_bitset/dynamic_bitset.hpp(1455): error: name followed by "::" must be a class or namespace name
const ios_base::fmtflags adjustfield = os.flags() & ios_base::adjustfield;
/usr/include/boost/dynamic_bitset/dynamic_bitset.hpp(1458): error: name followed by "::" must be a class or namespace name
if (adjustfield != ios_base::left) {
/usr/include/boost/dynamic_bitset/dynamic_bitset.hpp(1460): error: expression must have pointer-to-class type
if (Tr::eq_int_type(Tr::eof(), buf->sputc(fill_char))) {
/usr/include/boost/dynamic_bitset/dynamic_bitset.hpp(1461): error: identifier "err" is undefined
err |= ios_base::failbit; // G.P.S.
/usr/include/boost/dynamic_bitset/dynamic_bitset.hpp(1461): error: name followed by "::" must be a class or namespace name
& nbsp; ^
/usr/include/boost/dynamic_bitset/dynamic_bitset.hpp(1466): error: identifier "err" is undefined
if (err == ok) {
/usr/include/boost/dynamic_bitset/dynamic_bitset.hpp(1469): error: name followed by "::" must be a class or namespace name
typename buffer_type::int_type
/usr/include/boost/dynamic_bitset/dynamic_bitset.hpp(1470): error: expression must have pointer-to-class type
ret = buf->sputc(b.test(i-1)? one : zero);
/usr/include/boost/dynamic_bitset/dynamic_bitset.hpp(1472): error: name followed by "::" must be a class or namespace name
/usr/include/boost/dynamic_bitset/dynamic_bitset.hpp(1481): error: expression must have pointer-to-class type
/usr/include/boost/dynamic_bitset/dynamic_bitset.hpp(1482): error: name followed by "::" must be a class or namespace name
/usr/include/boost/dynamic_bitset/dynamic_bitset.hpp(1493): error: name followed by "::" must be a class or namespace name
try { os.setstate(ios_base::failbit); } catch (...) { rethrow = true; }
/usr/include/boost/dynamic_bitset/dynamic_bitset.hpp(1500): error: identifier "err" is undefined
if(err != ok)
/usr/include/boost/dynamic_bitset/dynamic_bitset.hpp(1448): error: basic_streambuf is not a template
typedef basic_streambuf buffer_type; // G.P.S.
detected during instantiation of "std::basic_ostream<_CharT, _Traits> &boost::operator<<(std::basic_ostream<_CharT, _Traits> &, const boost::dynamic_bitset &) [with CharT=char, Traits=std::char_traits, Block=unsigned long, Allocator=std::allocator]"
compilation aborted for bitset.cc (code 2)
The code to reproduce the problem is:
#include
#include
using namespace boost;
using namespace std;
int main()
dynamic_bitset<> bits(0);
cout << bits << endl;
return 0;
I use boost 1.33.1, which is the current stable version. The code responsible for the problems is as follows:
template
std::basic_ostream&
operator<<(std::basic_ostream& os,
const dynamic_bitset& b)
if (cerberos) {
BOOST_DYNAMIC_BITSET_CTYPE_FACET(Ch, fac, os.getloc());
const Ch zero = BOOST_DYNAMIC_BITSET_WIDEN_CHAR(fac, '0');
const Ch one = BOOST_DYNAMIC_BITSET_WIDEN_CHAR(fac, '1');
try {
typedef typename dynamic_bitset::size_type bitsetsize_type;
buffer_type * buf = os.rdbuf();
size_t npad = os.width() <= 0 // careful: os.width() is signed (and can be < 0)
|| (bitsetsize_type) os.width() <= b.size()? 0 : os.width() - b.size(); //- G.P.S.
const Ch fill_char = os.fill();
const ios_base::fmtflags adjustfield = os.flags() & ios_base:: adjustfield;
// if needed fill at left; pad is decresed along the way
for (; 0 < npad; --npad)
break;
if (err == ok) {
// output the bitset
for (bitsetsize_type i = b.size(); 0 < i; --i) {// G.P.S.
if (Tr::eq_int_type(Tr::eof(), ret)) {
break;
if (err == ok) {
// if needed fill at right
for (; 0 < npad; --npad) {
break;
&nbs p; }
os.width(0);
} catch (...) { // see std 27.6.1.1/4
bool rethrow = false;
if (rethrow)
throw;
if(err != ok)
os.setstate(err); // may throw exception
return os;
The problems can be easily solved by adding
using std::ios_base;
using std::basic_ostream;
using std::basic_streambuf;
at the top of the operator<< function, but I think this should not be necessary since it states using namespace std, so I think it could be problem with name lookup in the new compiler.
If needed, I can send the complete source code or the precompiled code.
icpc bitset.cc
&n bsp; ^
if (cerberos) {
& nbsp; ^
if (err == ok) {
if(err != ok)
#include
#include
int main()
return 0;
template
std::basic_ostream
if (cerberos) {
try {
break;
if (err == ok) {
break;
if (err == ok) {
break;
&nbs p; }
os.width(0);
if (rethrow)
throw;
if(err != ok)
return os;
I will look into the probelm asap. Is it possible or did you already prepared a reproducer ? If it's too complicated you can send me the precompiled code.
my apologies for the delay, but I have been off for vacation. I've just created an issue (no. 388524) in the support area with three files attached. The first file is the boost source code file, the second a simple demo program, and the last one contains the preprocessed output from the demo program. I have marked the problem site (operator<< in file dynamic_bitset.hpp) with a comment "// These using directives fixe problems with Intel C++ 9.1". The following three using directives solve the problem.
