Intel® C++ Compiler
7956 Discussions
Need help w C++ Composer on Linux....Need FlexLM for Linux
Dave_A__from_Lifeboa
NEW REQUEST Need the current level of Flexlm that is available for Linux for Red Hat EL 5.
And a path to that, as well as user guide.
Customer fighting a C++ Composer install and needs Flexlm for Linux can only find Windows version.
Thanks ....Dave A. from Lifeboat Distribution.
Om_S_Intel
There is an artcle how to download it. It is available using http://software.intel.com/en-us/articles/performance-tools-for-software-developers-intel-flexlm-license-servers/.
I am providing the short description below to down load.
You need to login to Intel registration center and go to page https://registrationcenter.intel.com/RegCenter/Download.aspx?productid=633. This page has dropdown list to select the approprite plateform to download FlexLM.
Om,
My customer reports the following:
It doesn't have a release V5 for Redhat.
only rel. 3, 4. and those versions don't run on our V5 Op. Sys.
See the last error message.
*** Error: installed software will not run; package might be for the wrong platform, or corrupted
I can try - again, in case it was corrupted, but I ask
Does this run on V5.6 Redhat ?
Hubert_H_Intel
Dave,
The error messagemay mean that 32-bit libs are missing on the license server since the Intel Flexlm License Manager is a 32-bit application that requires some portions of 32-bit system libraries.
The customer may try to find a 32-bit only machine for running the license manager services or install a 32-bit library package for RedHat 5.
Regards, Hubert.
