Intel® C++ Compiler
7956 Discussions
Need "wrapper" to compile the Linux kernel with ICC
TyMac
I am a developer with an idea to start a new kernel source for Gentoo that is specifically for the Intel ICC compiler. Evidentally there is a "wrapper" that is needed to be applied to the kernel source first before ICC can correctly complie the Linux kernel. Where can I get this wrapper? (I have looked all over the web but the only yhing I can find is old documentation)
Feilong_H_Intel
Quoting - thaidog
Is our kernel able to use IPO at all now?
I didn't get a chance toturn onIPO with 10.1or 11.0 compiler yet. I'll try it for sure some time later. If you see any problem with IPO, please let me know.
TyMac
Quoting - (Intel)
Quoting - thaidog
Ok will do! :)
TyMac
Quoting - (Intel)
me and newper were talking... it apeears there have been some changes:
"Something about IPO:
According to intel's doc,icc8 has an option called -ipo_obj,that
forces the compiler to create real object files when used with
-ipo,but now this option disappeared.
I tried to undef inline in the compiler-intel.h,but it seem has no use."
Is that going to be an issue?
TyMac
FYI I just started a Google Group for this:
http://groups.google.com/group/linuxdna
TyMac
I would also like to announce that our project LinuxDNA now has an offical partnership wth Dream Linux! If you have not tried Dream Linux you should download it. You will never have to go back to Windows once you do! We will be crating an ICC optimized version of Dream Linux for Atom based netbooks like the Asus Eee PC! Since there are no GCC specific optimizations available for the Atom cpu our Dream Linux build will be the fastest thing out there period! Pleas join our Google group if you would like to contribute and be a part of our team!
TyMac
Quoting - bustaf
Hi
you have fault syntax in your link
Is wrote http://www.lnuxdna.com/icc_dev_vm.tar.lzma
But are
http://www.linuxdna.com/icc_dev_vm.tar.lzma
Also
I am sorry that i can not make immediately
I have an task with RS/6000 AIX must be finished this week
Best regards
bustaf:
I was wondering if you see ny freexes with SuSE? I have reports that onDemend cpu freq scaling is not available with compiling on SuSE and that they are getting radom freezes. I have no idea why this would be happending... they are a linux newbie however.
Are you seeing anything like that on SuSE or OpenSuSE?
beartung
[cpp]my wrapper
ARGS=$@ # Add "-gcc" in the prevention of icc.cfg have "-no-gcc" ICCARGS="-fno-builtin -gcc" if [ -z "$ICC" ] then ICC=icc fi if [ -z "$GCC" ] then GCC=gcc fi for ARG in $@ do case $ARG in -fno-stack-protector ) ICCARGS="$ICCARGS -fno-stack-security-check" ;; -O2 | -O3 ) ICCARGS="$ICCARGS -O2" ;; -v ) $ICC --version 2>&1 | grep "icc" exit 0 ;; */boot/* ) $GCC $ARGS exit $? ;; # ignore these gcc options -fno-unit-at-a-time | -fno-inline | -g | -gstabs |-maccumulate-outgoing-args|-mno-3dnow|-mno-mmx | -mno-sse | -mno-sse2 |-mpreferred-stack-boundary=2 |-msoft-float | -nostdinc | -pipe | -Wall | -Werror | -Wno-pointer-sign ) ;; * ) ICCARGS="$ICCARGS $ARG" ;; esac done $ICC $ICCARGS exit $?
[/cpp]
my kernel is 2.6.28.8, icc is 11.081.
what i have modified:
Makefile
script/Makefile.build
script/Makefile.modpost
add /opt/intel/Compiler/11.0/081/lib/ia32/libirc_s.a
include/linux/compiler-intel.h
add #undef __compiler_offsetof
then i make CC=kicc HOSTCC=kicc LD=xild AR=xiar V=1 bzImage
bzImage is ok, but when i make modules, i got this:
Building modules, stage 2.
make -f /usr/src/linux-2.6.28.8-icc/scripts/Makefile.modpost
scripts/mod/modpost -o /usr/src/linux-2.6.28.8-icc/Module.symvers -S -K /usr/src/linux-2.6.28.8-icc/Module.markers -M /usr/src/linux-2.6.28.8-icc/Module.markers -s
ERROR: "snd_pcm_format_width" [sound/pci/hda/snd-hda-intel.ko] undefined!
ERROR: "kmalloc_caches" [sound/pci/hda/snd-hda-intel.ko] undefined!
ERROR: "pci_bus_read_config_byte" [sound/pci/hda/snd-hda-intel.ko] undefined!
ERROR: "__kmalloc" [sound/pci/hda/snd-hda-intel.ko] undefined!
ERROR: "msleep" [sound/pci/hda/snd-hda-intel.ko] undefined!
ERROR: "kmalloc_caches" [arch/x86/kernel/test_nx.ko] undefined!
ERROR: "printk" [arch/x86/kernel/test_nx.ko] undefined!
WARNING: modpost: Found 14 section mismatch(es).
To see full details build your kernel with:
'make CONFIG_DEBUG_SECTION_MISMATCH=y'
make[1]: *** [__modpost] 1
make: *** [modules] 2
so, anyone have got the same problem? need help.
Quoting - thaidog
bustaf:
newper
Find
#define __EXPORT_SYMBOL(sym, sec)
extern typeof(sym) sym;
__CRC_SYMBOL(sym, sec)
static const char __kstrtab_##sym[]
__attribute__((section("__ksymtab_strings"), aligned(1)))
= MODULE_SYMBOL_PREFIX #sym;
static const struct kernel_symbol __ksymtab_##sym
__used
__attribute__((section("__ksymtab" sec), unused))
= { (unsigned long)&sym, __kstrtab_##sym }
in include/linux/module.h
remove 'static',before const char __kstrtab_##sym[] and const struct kernel_symbol __ksymtab_##sym
beartung
thanks!
i tried. bzImage is ok, modules get a new error!
[shell]Building modules, stage 2.
make -f /usr/src/linux-2.6.28.8/scripts/Makefile.modpost
  scripts/mod/modpost   -o /usr/src/linux-2.6.28.8/Module.symvers    -S -K /usr/src/linux-2.6.28.8/Module.markers -M /usr/src/linux-2.6.28.8/Module.markers   -s
ERROR: "__bad_udelay" [drivers/net/e1000e/e1000e.ko] undefined!
[/shell]
Quoting - newper
Find
__used
beartung
i used the icc kernel and gcc modules boot
it looks like everything is ok ....
but i want to know how to build the modules using icc?
Quoting - beartung
beartung
i found two symbols which kernel not defined...
nm vmlinux-icc|grep ' U ':
U ____ilog2_NaN
U __bad_udelay
so when i make modules got error:
Quoting - beartung
newper
Try this,though it's really not a good solution
Open arch/x86/include/asm/delay.h
Delete these:
extern void __bad_udelay(void);
extern void __bad_ndelay(void);
(n) > 20000 ? __bad_udelay() :
(n) > 20000 ? __bad_ndelay() :
Feilong_H_Intel
Quoting - newper
Delete these:
newper's workaround should work. Thanks newper.
Feilong
beartung
thanks newper and Feilong
i have changed icc to 10.1.022, both kernel and modules built. it works well : )
i will try icc 11 using your way too.
Quoting - Feilong H. (Intel)
Feilong
TyMac
Feilong we have someone wanting to compile an IA64 kernel... you have done that before right?
Feilong_H_Intel
Quoting - thaidog
Didyou meant to say Intel 64 or IA-64 (Itanium)?
TyMac
Quoting - thaidog
I think he means Itanium.
Feilong_H_Intel
Quoting - thaidog
I compiled 2.6.9 kernel for IA-64 with icc 9.1 a few years ago. Due to my resource limitation, I didn't work on IA-64 kernel since then. The most part of the patch file is replacing inline asm code with intrinsics because icc for IA-64 doesn't support inline asm. If you are interested in compiling an IA-64 kernel, i'd be happy to assist you.
TyMac
Quoting - thaidog
Well I do not have an Itanium cpu to test on but I will forward this to LuYi since he got the e-mail rom the person who wanted to try :)
TyMac
Feilong I have been trying to get in touch with somebody at Intel about our project. We have a full LiveCD based in ICC that is ready to go but we do not have a Professional compiler license so we can not distrbute it. I was hoping that Intel would help us out with this due to the popilarity of the project.
Do you have somebody on the "inside" we could talk to about this project?
melayuboleh
Quoting - thaidog
i hope this post will help you,
http://www.gentoo-wiki.info/HOWTO_ICC_and_Portage
and
http://www.intel.com/cd/software/products/asmo-na/eng/compilers/284264.htm
Hope it help as your reference
