I have a function that finds the turning point of a composite curve consisting of multiple sine curves. Can anyone suggest anything I can do to get this function to vectorize?
I tried turning Curves
Can anyone think of a clever way this could be re-arranged so it vectorizes?
Thanks in advance.
class SineTurns
public:
unsigned int CurvesC;
float **CurvesV;
float Value;
SineTurns ();
void Search ();
SineTurns::SineTurns () {}
void SineTurns::Search ()
static float Frequencies[MAXCURVES];
static float SearchSpace[MAX_TURN_DISTANCE];
int x;
float xx;
unsigned int i;
int x1; // x+1
int x2; // x+2
for (i = 0; i < CurvesC; i++)
Frequencies = 1.0f / CurvesV[0];
bzero(SearchSpace, MAX_TURN_DISTANCE);
for (x = 0, xx = 0; x > -MAX_TURN_DISTANCE; x--)
#pragma ivdep // Bogus flow dependence without ivdep
// dereference too complex with ivdep :-(
SearchSpace+= CurvesV[2] * sinf (Frequencies * xx + CurvesV[1]) + CurvesV[3];
xx--;
if (x < -1)
x1 = x + 1;
x2 = x + 2;
if ( (SearchSpace[x1] > SearchSpace&& SearchSpace[x1] > SearchSpace[x2]) ||
(SearchSpace[x1] > SearchSpace&& SearchSpace[x1] > SearchSpace[x2]))
Value = SearchSpace[x1];
break;
This vectorizes very well with Intel C++ 10.027 if you make the memory traversal unit stride for the CurvesV array.
Lars Petter Endresen
for (i = 0; i < CurvesC; i++){
SearchSpace
+= CurvesV[2] * sinf (Frequencies * xx + CurvesV[1]) + CurvesV[3]; }
What exactly do you mean by that?
I tried what you suggested (turning and
I usually lean toward trusting the compiler's guess on such things, because it usually means something isn't aligned properly. Granted, CurvesV is a float**, so the compiler won't necessarily know how it's aligned, but is that the only problem? If so I'm not bothered (I can ensure that I align the CurvesV[][] properly at new() time, but I'm concerned that there could be something else causing inefficiency there.
With 10.0.026, I get "remark: loop was not vectorized: unsupported loop structure."
I am very sorry for the confusion. Indeed if the loop trip count is too low, vectorizing may not always be efficient. Please read Aart Bik's excellent bookabout vectorization. I guessed that the loop had trip count of 640,
#include
#define
MAXCURVES 640#define
MAX_TURN_DISTANCE 640
which gave the following efficient code, calling the optimized SVML (Short Vector Math Library) math function ___svml_sinf4,
movups xmm1, XMMWORD PTR [esi+edi*4] movaps xmm0, XMMWORD PTR Frequencies$170$0$0[0+edi*4]mulps xmm0, XMMWORD PTR [esp+32] addps xmm0, xmm1 call ___svml_sinf4
I don't know if this is still an issue since it is several months old,
but I've found that using class variables in a loop can prohibit vectorization.
This goes even for the loop count variable. For example you might try
reassigning 'CurvesC' and 'CurvesV' to local variables:
int count = CurvesC;
float *C1 = &(CurvesV[1][0]);
float *C2 = &(CurvesV[2][0]);
float *C3 = &(CurvesV[3][0]);
#pragma ivdep
for (i = 0; i < count; i++)
SearchSpace
+= C2 * sinf (Frequencies * xx + C1) + C3; I'm guessing the two-dimensional arrays aren't a problem,
but generally you should try to simplify the code as much as possible
for easier parsing by the vectorizer.
Mike
Sorry that last post came out kind of messy but hopefully you get the idea.
-Mike
I guessed that the loop had trip count of 640,#include
#define MAXCURVES 640
#define MAX_TURN_DISTANCE 640
640 is an order of magnitude out, but my understanding is that
even a trip count of 4 can be sufficient for effective vectorization.
MAXCURVES is 16 (but it's typically between 4 and 8, 16 is
just the hard limit, actual number is CurvesC).
MAX_TURN_DISTANCE is 64. I guess this makes it reasonable to
just tell the compiler to vectorize anyway and be done with it.
Strange, the code always vectorizes in my simple test project, even with trip count as low as 4.I am using Visual Studio 2005 with Intel C++ 10.027.
Does your testcase include the C++ class structure?As I wrote in the earlier post,classvariable references can inhibit vectorization. You can also use "#pragma loop count (x)" to give the compiler a hint about loop trip counts.
-Mike
