Just loaded Intel C++ compiler and idb on MacBook. Compiler runs fine; idb does not. Pertinant info:
$icc --version
icc (ICC) 9.1 20060707
Copyright (C) 1985-2006 Intel Corporation. All rights reserved.
$idb --version
idb --version
Intel Debugger for IA-32 -based Applications, Version 9.1-24 , Build 20060622
Simple hello world foo.c.
$ icc -g foo.c
$ a.out
Foo
Here's what I get when I try to run idb:
$idb a.out
object file name: a.out
Reading symbolic information from /Users/xxx/foo/a.out...You cannot debug "/private/tmp/icc27SJcU.o" because its type is "unknown".
IDB could not read debugging info from /private/tmp/icc27SJcU.o
No debugging symbols found
I did just download the latest Intel compiler (029), and loaded both compiler and idb. Updated to Xcode 2.4 before all these installations. I compiled with gcc and used gdb, and debugger worked fine.
Any help? thanks
$icc --version
$idb --version
idb --version
$ icc -g foo.c
$ a.out
Foo
$idb a.out
Any help? thanks
Thanks Bill. I'll attempt to reproduce in-house and then work with IDB developers on a resolution.
-- G
Bill,
I believe the debugging information is removed from executables on MacOS. Please try doing:
$ icc o foo.o gdwarf-2 c foo.c
$ icc o a.out foo.o
$ a.out
Foo
$idb a.out
The corresponding object file must be in the same place it was in when the executable was compiled, or IDB wont find the debugging information.
Please let me know how that works for you.
-- G
I have the same problem with the Intel fortran90 compiler and debugger on an Intel-based MacBook Pro. The -gdwarf-2 option did not help.
I also have the problem that I can't get XCode to work with the Intel Debugger, either. Is there a way to get around this? Thanks for your help!
Stan
Stan
IDB that comes with version 10.1 is only supported from the command line. Xcode integration is not available.
