Consider the following code:
double* a;
size_t n;
a[0:n] = log(a[0:n]);
The compiler reports that _log cannot be vectorized. Reports the same for the pow() function. However, changing to functions such as exp(), sin(), etc. allow vectorization. I thought that log() and pow() were vectorizable functions as in http://software.intel.com/sites/products/documentation/doclib/iss/2013/compiler/cpp-lin/GUID-E98D4E0.... Does anyone know the cause?
I can try those workarounds, but I don't know what is different about log() and pow(). This is the output from level 6:
vectorization support: call to function _log cannot be vectorized.
Same occurs with pow(), with the statement referencing the _pow function.
Your example would require #include <math.h> and possibly a change from size_t to int.
Actually I have #include <mathimf.h> in the file. Isn't that what is required? Why int? It's the same size on 32 bit builds and I believe technically wrong for 64 bit builds.
Again, these would not explain why other math functions work.
I figured out what is causing it not to be vectorized. The use of /fp:precise. However, I don't understand why that switch will affect only certain functions while others can be vectorized.
So you can see why everyone has been asking for a reproducer.
In recent compilers, increasing numbers of svml function invocations are disabled by /fp:precise. That some of them slipped by in the past may have been an oversight. svml functions aren't designed to permit capturing exceptions on individual operands. If you wish to over-rule this effect on math function vectorization, you may set /Qfast-transcendentals.
In principle, you may also need to consider the /Qimf- options. The svml default "guarantees" accuracy only within 4 Ulps (although it is usually better), which is not consistent with expectation for /fp:precise. exp() and pow() functions (and their relatives) are notoriously difficult to vectorize while maintaining full accuracy for corner cases. /Qimf-... allows you to request higher precision/slower or lower/faster functions if they exist.
I noticed a case this week where disabling svml vectorization by -fp-model source doesn't affect vec-report. Apparently, the decision not to report the difference between full vectorization with and partial vectorization without /Qcomplex-limited-range has been carried over to /Qfast-transcendentals.
I had to revise my recommendation for options to observe parentheses while allowing maximum optimization to include fast-transcendentals:
/fp:source /Qftz /Qfast-transcendentals [/Qprec-div- /Qprec-sqrt-]
This still disables vectorization of sum and indexed max/min reductions.
Thanks for the information everyone. Do you still want a repro case as all I did was extract this from a much larger program? My repro case really doesn't do anything more than here.
Tim, do you know the accuracy of the VC++ library in /fp:precise and /fp:fast mode? Since part of my application is compiled with it, I suspect I may need similar accuracies for the various modules.
Microsoft /fp:fast vs. /fp:precise don't affect their math libraries, as far as I know. Most of them, particularly if based on x87 code, should be what Intel calls "high" accuracy. I don't believe there are any vector math functions in the Microsoft libraries. If it's critical, you may want /Qimf-precision:high versions for Intel vector libraries (high accuracy is the default for the scalar functions). Although ICL /fp:source is roughly equivalent to Microsoft /fp:fast, the more aggressive ICL default /fp:fast affects math function accuracy only when it promotes vectorization and imf-precision is set to medium (default) or low (where double "low" is barely better than float high precision).
By the way, /Qimf-precision also affects vectorized divide and sqrt, but /Qprec-div /Qprec-sqrt will force those independently to full accuracy.
Sergey, thanks for the info. I'll look into it.
