Intel® C++ Compiler
7932 Discussions
Not possible to upgrade Eclipse project files to Parallel Studio XE 2015 Linux
martin_forstzenotrac
I have upgraded to Parallal Studio XE 2015 for Linux. Is there a way to ugrade the Eclipse project files from the previous version?
Eclipse shows "Orphaned configuration. No base extension cfg exists for intel.linux.x86_64.so.rel.1379479560_14.0.0"
There is no "Intel Tools" menu showing up where it was possible to upgrade project files from previous versions.
Im using XUbuntu 14.04, Eclipse Kepler
qigong
I have encountered the same issue. Have someone got any proper way to upgrade existing xe_14 projects to xe_15? Thanks.
No, I habe not found a solution for this issue, I created new project files. I now switched to Qtcreator because it is easy to try different compilers and it allows to collect Compiler switched in a config file.
Shenghong_G_Intel
Hi all,
Q1: How to switch between different Intel compiler versions?
Q2: How to switch between different compilers?
For project upgrading, I assume you only need to change these settings.
Note: In the 2015 integration, there is no "intel tools" menu item, which is expected.
Hope it helps.
Shenghong
