Intel® C++ Compiler
Numerous #1885 warnings when compiling an MFC project under VS-2012
Evgeniy_B_
In our MFC projects ICC spams hundreds of warnings:
                warning #1885: #pragma region unclosed at end of file
While narrowing down the cause of this warning I noticed it does not reproduce under VS-2010, I’m  getting it under VS-2012 only. So I guess it has something to do with MFC headers that come with VS-2012.
PS: Intel C++ Composer XE 2013 (Update 1, Update 2 and Update 3).
SergeyKostrov
Valued Contributor II
>>In our MFC projects ICC spams hundreds of warnings: >> >> warning #1885: #pragma region unclosed at end of file >> >>While narrowing down the cause of this warning I noticed it does not reproduce under VS-2010, I’m getting it under VS-2012 only. >>So I guess it has something to do with MFC headers that come with VS-2012 MFC is a very large library and I wonder if you could be more specific? Is there any chance to create a small reproducer based on a default MFC project from a VS Projects Wizard ( MDI, or SDI, or Dialog based )?
petervk
Reproducing this is trivial. If needed, I can upload the default project produced, but you can save 76MB of downloads by performing the following steps:
  1. Create a new MFC application in VS 2012 (File>New>Templates>Visual C++>MFC>MFC Application).
  2. Default name is MFCApplication1. Press OK.
  3. Press Finish in the wizard.
  4. In the solution properties, for Intel compiler, select Use Intel C++.
  5. Build.
  6. warning #1885: #pragma region unclosed at end of file errors appear for each included file.
This behavior does not appear with MFC applications created with Visual Studio 2010 or earlier.
Evgeniy_B_
Sure, here's a small test project.
SergeyKostrov
Thanks, Evgeniy! I'm already looking into this. So, could you post a compilation output ( as much as possible lines! ) before that warning message? >>In our MFC projects ICC spams hundreds of warnings: >> >>warning #1885: #pragma region unclosed at end of file
SergeyKostrov
Here is a completely isolated test case to reproduce that 1885 warning: #pragma region Region_1 void Test() {} void Test2() {} void Test3() {} // #pragma endregion Region_1 int main( void ) { return ( int )0; } Note: It is the same as on msdn.microsoft.com/en-us/library/b6xkz944(v=vs.80).aspx. Here is a workaround: #pragma warning ( disable : 1885 ) and it disables that warning.
SergeyKostrov
Here are two references with a description of #pragma region directive: [ Intel Docs ] Intel(R) C++ Compiler User and Reference Guides Document number: 304968-023US ... Intel Supported Pragmas ... region/endregion - specifies a code segment in the Microsoft Visual Studio* 2005 Code Editor that expands and contracts by using the outlining feature Page 1722 [ Microsoft Docs ] Web-link: msdn.microsoft.com/en-us/library/b6xkz944(v=vs.80).aspx #pragma region lets you specify a block of code that you can expand or collapse when using the outlining feature of the Visual Studio Code Editor. Remarks #pragma endregion marks the end of a #pragma region block. A #region block must be terminated with #pragma endregion.
SergeyKostrov
Another thing to look at are Afx-like and windows.h header files: [ Stdafx.h ] ... #include #include // MFC core and standard components #include // MFC extensions #ifndef _AFX_NO_OLE_SUPPORT #include // MFC support for Internet Explorer 4 Common Controls #endif #ifndef _AFX_NO_AFXCMN_SUPPORT #include // MFC support for Windows Common Controls #endif // _AFX_NO_AFXCMN_SUPPORT // Windows Header Files: #include ... Just comment all of them and verify that the warning 1885 is no longer displayed. Then, start uncommenting these headers one at a time from the last one, that is, from windows.h and re-building the test project. The goal is to find a header that has a mismatched pair of #pragma region directives. Evgeniy, all of that looks like a problem with MFC headers but I'm still leaving some very small possibility that this is a problem with Intel C++ compiler. I hope that Intel software engineers will investigate.
Evgeniy_B_
Yeah I agree, it looks like an MFC issue. Though while the real cause could be a Microsoft’s responsibility, Intel engineering team may want to suppress generation of the warning for Windows SDK headers (since numerous unrelated warnings could confuse the user).
SergeyKostrov
>>...since numerous unrelated warnings could confuse the user... I also don't like some warning messages ( however, I really like /W5 and /Wcheck options of Intel C++ compiler since they provide additional information which could help to improve overall quality of codes ). The workaround I've mentioned in one of my previous post: >>Here is a workaround: >> >>#pragma warning ( disable : 1885 ) >> >>and it disables that warning. should work.
Evgeniy_B_
Yeah it works, but it's just a workaround.
#pragma warning is quite useful when you want to suppress warnings for 3rd-party headers or if the compiler treats you as a dummy. Though in my opinion compiler should not generate warnings for standard platform headers (since API/SDK user has nothing to do with its quality). And I believe ICC already does so for the other warnings.
I would guess (aside from the most likely MFC issue) the warning is being generated because of how ICC treats #pragma region/endregion blocks. It looks like ICC tries to find matching #pragma endregion in a whole compilation unit, whereas as an outlining feature #pragma region/endregion block should be limited to a single file (well at least I think it should be, not sure how it correlates to C/C++ standard and extension definition).
jimdempseyatthecove
Perhaps the #pragma endregion is conditionalized out when compiling with ICC. This would be MFC issue. Meaning you will need to disable/enable 1855 around #include < fromMFC >
Jim Dempsey
