Intel® C++ Compiler
7875 Discussions
OMP: Error #13: Assertion failure at kmp_atomic.cpp(3935).
Doron
I am compiling a C++ program on Fedora 34 with MKL 2022.0.2.
In the code I have an std::atomic class member to manage access to my custom class object.
When I try to access the object I get the SIGABRT with the above message printed to the console.
What am I doing wrong?
VarshaS_Intel
Could you please provide us with the sample reproducer code along with the steps to reproduce the issue?
And also, could you please let us know the C++ compiler you are using(Intel Classic compiler(icpc)/LLVM compiler(icpx)) ?
Thanks & Regards,
Varsha
Doron
Hi Varsha
I am using: gcc (GCC) 11.3.1 20220421 (Red Hat 11.3.1-2).
The project uses cmake with: set(CMAKE_CXX_STANDARD 17)
 The attached project reproduces the problem with a small subset of the code.
Let me know if you need any additional information.
VarshaS_Intel
We are working on your issue. We will get back to you soon.
Thanks & Regards,
Varsha
VarshaS_Intel
Apologies for the delay in my response.
Could you please provide us with a complete sample reproducer since we did not find any MKL function usage, in order to find the root cause of the error?
Thanks & Regards,
Varsha
Doron
Hi Varsha
Have you been able to compile and run the test project I shared? I am not sure how it is related to MKL, but when I run it I get the following message:
OMP: Hint Please submit a bug report with this message, compile and run commands used, and machine configuration info including native compiler and operating system versions. Faster response will be obtained by including all program sources. For information on submitting this issue, please see http://www.intel.com/software/products/support/.
Aborted (core dumped)
If compile the same code without linking with MKL, I get the following:
/usr/bin/ld: CMakeFiles/test.dir/main.cxx.o: in function `main':
main.cxx:(.text.startup+0x1d): undefined reference to `__atomic_load'
It seems like MKL provides the implementation to atomic load.
Hope this helps
Doron
VarshaS_Intel
Could you please try using the Intel Compilers(icc,icx,icpx) and let us know what errors you are facing?
Thanks & Regards,
Varsha
VarshaS_Intel
We have not heard back from you. Could you please provide us with an update?
Thanks & Regards,
Varsha
Doron
Hi Varsha
I don't have the Intel compiler installed.
Did you try to compile the project I sent?
Cheers
Doron
VarshaS_Intel
Yes, we have tried the project you had send to us. But with the Intel ICC compiler, we are facing different errors related to the code issue.
Please find the below screenshot where we are getting the error:
We don't see a default constructor for Matrix4x4 defined. The declaration
std::atomic<Matrix4x4> _data;
defines _data as a trivially copyable object but it's a complex data type without a default constructor defined. For example, is the intent here (in main.cxx) to define this object as Matrix4x4 of strings or Vector3D objects defined in Matrix4x4.h or doubles as some of the provided constructors may suggest?
Basically, the operations std::atomic are available on trivially copyable types but beyond that, the std::<atomic> requires more careful design.
Could you please provide us with a valid test case?
Thanks & Regards,
Varsha
VarshaS_Intel
We have not heard back from you. Could you please provide us with a valid test case?
Thanks & Regards,
Varsha
VarshaS_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks & Regards,
Varsha
Doron
Hi Varsha
Sorry for the late replay and happy new year.
Based on your feedback I did some testing and as you mentioned the Matrix4x4 doesn't meet the requirements to be used as the template type for atomic.
I am not sure why GCC doesn't issue a compile time error, but it's definitely not an MKL issue.
Feel free to close this issue.
Thanks for the support
Doron
