Hi guys,
I compiled my application with ICC 2013 on several machines and it works well.
I recevie an error message only with one machine:
OMP: Error #13: Assertion failure at kmp_runtime.c(8139).
OMP: Hint: Please submit a bug report with this message, compile and run commands used, and machine configuration info including native compiler and operating system versions. Faster response will be obtained by including all program sources. For information on submitting this issue, please see http://www.intel.com/software/products/support/.
I read about similiar problem in the forum and set the enviroment variables:
KMP_SETTINGS=1
KMP_VERSION=1
And I get:
Effective settings:
KMP_ABORT_DELAY=0
KMP_ABORT_IF_NO_IRML=false
KMP_AFFINITY="noverbose,none"
KMP_ALIGN_ALLOC=64
KMP_ALL_THREADPRIVATE=128
KMP_ALL_THREADS=2147483647
KMP_ASAT_DEC=1
KMP_ASAT_FAVOR=0
KMP_ASAT_INC=4
KMP_ASAT_INTERVAL=5
KMP_ASAT_TRIGGER=5000
KMP_ATOMIC_MODE=2
KMP_BLOCKTIME=200
KMP_CPUINFO_FILE: value is not defined
KMP_DETERMINISTIC_REDUCTION=false
KMP_DUPLICATE_LIB_OK=false
KMP_FORCE_REDUCTION: value is not defined
KMP_FOREIGN_THREADS_THREADPRIVATE=true
KMP_FORKJOIN_BARRIER="2,2"
KMP_FORKJOIN_BARRIER_PATTERN="hyper,hyper"
KMP_GTID_MODE=3
KMP_HANDLE_SIGNALS=false
KMP_INIT_AT_FORK=true
KMP_INIT_WAIT=2048
KMP_ITT_PREPARE_DELAY=0
KMP_LIBRARY=throughput
KMP_LOCK_KIND=queuing
KMP_MALLOC_POOL_INCR=1M
KMP_MONITOR_STACKSIZE: value is not defined
KMP_NEXT_WAIT=1024
KMP_NUM_LOCKS_IN_BLOCK=1
KMP_PLAIN_BARRIER="2,2"
KMP_PLAIN_BARRIER_PATTERN="hyper,hyper"
KMP_REDUCTION_BARRIER="1,1"
KMP_REDUCTION_BARRIER_PATTERN="hyper,hyper"
KMP_SCHEDULE="static,balanced;guided,iterative"
KMP_SETTINGS=true
KMP_SSP_MAX_THREADS=0
KMP_STACKOFFSET=0
KMP_STACKSIZE=4M
KMP_STORAGE_MAP=false
KMP_TASKING=2
KMP_TASK_STEALING_CONSTRAINT=1
KMP_USE_IRML=false
KMP_VERSION=true
KMP_WARNINGS=true
OMP_DYNAMIC=false
OMP_MAX_ACTIVE_LEVELS=2147483647
OMP_NESTED=false
OMP_NUM_THREADS: value is not defined
OMP_WAIT_POLICY=PASSIVE
I also verified that only one omp library is linked to my application.
My OS is Ubuntu 12.04.
Please advise
