Dear all,
We received two reports
OMP : Error # 134 Cannot set thread affinity mask.
OMP: System error #87: The parameter is incorrect."
from IPP and MKL forum:
http://software.intel.com/en-us/forums/showpost.php?p=177075
http://software.intel.com/en-us/forums/showthread.php?t=103306
and Amplifier XE forum: http://secure-software.intel.com/en-us/forums/showthread.php?t=81551
There is possible test case in http://software.intel.com/en-us/forums/showthread.php?t=76294
( Uvsl.cs, where we try MKL 10.3.9 from composer XE and x86, mkl_rt.lib, OMP_NUM_THREADS=4096, it mayOS-related and cpu core number. the machine runing window server2003R2 X64 SP2and4 core x2 processorx2 HT =16 threadcan't reproduce the probelm.)
Could any OpenMP engineerhelp to see the probelm?
Thanks in advance!
YingH.
Thanks in advance!
YingH.
The fix should be available inComposer XE 2011 update 9 or MKL 10.3.9. Which update did you use?
Hope this helps,
--Vladimir
Hi Vladimir,
Thanks much for the reply. No wonder i can't reproduce the problem on my machine. Could you tell more about the problem?Here isin Composer XE bug fix list,
http://software.intel.com/en-us/articles/intel-composer-xe-2011-compilers-fixes-list/
does this onecorresponds to the problem?
Ying H.
DPD200135764 | C | access violation in libiomp5md.dll |
Ying H.
Quoting Ying H (Intel)
Hi everybody,
It would be nice to clarify it because an'access violation' and a'thread affinity' are different things but it is
possible that they are related.
Sergey
