Hi ..
I am trying to make a comparison statistics of offload using,
1). Intel compiler assisted offload VS. 2). OPENMP 4.0 target construct
My QUESTION: HOW I CAN GET OPENMP 4.0 OFFLOAD REPORT(which environment variable I need to set..?), I used OFFLOAD Report=2; intel compiler directive offload it worked fine, BUT I AM GETTING VERY STRANGE STATISTICS WITH OPENMP 4.0 OFFLOAD (I am using Intel Xeon Phi as execution platform)
Here is the code
COMPILER DIRECTIVE OFFLOAD:
// Start time
gettimeofday(&start, NULL);
// Run SAXPY
#pragma offload target(mic:0) inout(x) out(y)
#pragma omp parallel for default (none) shared(a,x,y)
for (i = 0; i < n; ++i){
y = a*x + y;
} // end of target data
// end time
gettimeofday(&end, NULL);
OPENMP 4.0 TARGET OFFLOAD:
// Start time
// Run SAXPY
#pragma omp target data map(to:x)
#pragma omp target map(tofrom:y)
y = a*x + y;
Thanks in advace. (Raju)
I would have written #pragma omp target map (to: x) map( tofrom: y){
similar to what works in Fortran, but who am I to say when I haven't had much success with C?
The offload report does support the OpenMP 4.0 target construct. The environment variable is OFFLOAD_REPORT. See the documentation here for usage (search 'offload report'): https://software.intel.com/en-us/intel-cplusplus-compiler-16.0-user-and-reference-guide
I noticed that the documentation does not mention OpenMP support for this feature so I have submitted a change request to include that information (DPD200376289).
--Amanda
