Intel® C++ Compiler
OPENMP 4.0 target offload Report
Rezaul_R_
Hi ..
I am trying to make a comparison statistics of offload using,
1). Intel compiler assisted offload VS. 2). OPENMP 4.0 target construct
My QUESTION: HOW I CAN GET OPENMP 4.0 OFFLOAD REPORT(which environment variable I need to set..?), I used OFFLOAD Report=2; intel compiler directive offload it worked fine, BUT I AM GETTING VERY STRANGE STATISTICS WITH OPENMP 4.0 OFFLOAD (I am using Intel Xeon Phi as execution platform)
Here is the code
COMPILER DIRECTIVE OFFLOAD:
// Start time
        gettimeofday(&start, NULL);
        // Run SAXPY
        #pragma offload target(mic:0) inout(x) out(y)
                        #pragma omp parallel for default (none) shared(a,x,y)
                        for (i = 0; i < n; ++i){
                                y = a*x + y;
        } // end of target data
        // end time
        gettimeofday(&end, NULL);
OPENMP 4.0 TARGET OFFLOAD:
// Start time
        // Run SAXPY
        #pragma omp target data map(to:x)
                #pragma omp target map(tofrom:y)
                                y = a*x + y;
Thanks in advace. (Raju)
TimP
Black Belt
I would have written #pragma omp target map (to: x) map( tofrom: y){
similar to what works in Fortran, but who am I to say when I haven't had much success with C?
Amanda_S_Intel
The offload report does support the OpenMP 4.0 target construct. The environment variable is OFFLOAD_REPORT. See the documentation here for usage (search 'offload report'): https://software.intel.com/en-us/intel-cplusplus-compiler-16.0-user-and-reference-guide
I noticed that the documentation does not mention OpenMP support for this feature so I have submitted a change request to include that information (DPD200376289).
--Amanda
