Community
cancel
Showing results for
Search instead for
Did you mean:
Toshio_U_
[OS X] a tuple of tuples
The following code contains a std::tuple of tuples. It can be successfully compiled with c++ compiler provided by Apple but fails with icpc-15.0.2.132 under OS X 10.10(Yosemite).
#include <tuple>
int
main()
    using namespace    std;
    tuple<tuple<int, float>, tuple<long, double> > x;
    return 0;
Feilong_H_Intel
Hi there,
I've entered this issue to our  problem-tracking database.  Thank you for your small test case!
Feilong_H_Intel
This issue has been addressed in 16.0 compiler and in 15.0.4 compiler .  FYI.
