Intel® C++ Compiler
7957 Discussions
OSX/Linux error: use of undeclared identifier '_mm_loadu_si32'
Mykola83
Intel Intrinsic Guide states it's pretty old SSE2 instruction,
https://software.intel.com/sites/landingpage/IntrinsicsGuide/#text=_mm_loadu_si32&expand=3419
but why I can't find it on Linux/OSX ?
On OSX I searched through
/Library/Developer/CommandLineTools/usr/lib/tapi/10.0.0/include/emmintrin.h
but nothing found.
AbhishekD_Intel
Please update us if the provided details help you. As this is Intel Intrinsic we will recommend you to use Intel Compiler. We can only provide support to the Intel specific issues.
As this intrinsic is already present so can we close this thread?
If you have any issues related to this thread please update us. Also, feel free to post a new thread if have more Intel compiler-related issues.
Warm Regards,
Abhishek
AbhishekD_Intel
It seems that you are not looking "_mm_loadu_si32" into the correct file.
Please try searching this in "immintrin.h" header file, you will definitely find it.
I have checked it in my environment and its there. Please find the below result for more details.
[]$ cat /opt/intel/compiler/2020u1/compilers_and_libraries_2020.1.217/linux/compiler/include/icc/immintrin.h | grep -i _mm_loadu_si32
extern __m128i __ICL_INTRINCC _mm_loadu_si32(void const*);
[]$ icc -v
icc version 19.1.1.217 (gcc version 4.8.5 compatibility)
Warm Regards,
Abhishek
Mykola83
Actually, I don't use Intel compiler.
I use gcc/clang.
Viet_H_Intel
These are Intel Intrinsic. You need to have Intel compiler installed in order to use them.
Mykola83
I have Intel compiler installed.
But what I found is that my problem really exists.
And it was fixed only last year in GCC 9 !!!
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=78782
AbhishekD_Intel
Warm Regards,
Abhishek
AbhishekD_Intel
Please give us an update related to this issue.
Thank You
Mykola83
Ok, lets close the issue, as not Intel issue.
AbhishekD_Intel
Thank you for the confirmation. We will no longer monitor this issue. Feel free to post a new thread if you have any issues.
