Did you download from the Intel Eval Center at:http://software.intel.com/en-us/articles/intel-software-evaluation-center/ or from elsewhere?
The Intel Parallel Composer/Compsoer XE2011 Update 6 should be the version available in the eval center.Update 6 was released 6th Sept 2011. I'll check the eval download center.
Hubert.
Open a command prompt and type icl /v, and you will be shown the version number. You can also check the version number in a number of places, including the Start Menu, or the Programs and Features control panel.
s:\>icl /? | grep 0x
Intel C++ Compiler XE for applications running on IA-32, Version 12.1.0.233 Build 20110811
Copyright (C) 1985-2011 Intel Corporation. All rights reserved.
c++0x enable preliminary support for some C++0x features
Dix,
I looked up in the Intel Evaluation Center.
Unfortunately for the Intel Parallel Composer 2011 the default download is the 'Initial Release', not Update 6. You need to choose 'Update 6' from the 'Update (Build #) drop-down box in the download area and then select a download file.
For the Intel Composer XE 2011 the default download is the latest version 2011 Update 6.
Which is the version you actually installed?
Hubert.
C++ Composer XE is the basic C++ compiler.
If you want to try a different evaluation product, simplest way is to start a new evaluation.
Hi Dix,
So you need to download the Update 6 as I explained in the last communication. Please open the link from the registration email you got from the Intel Registration Center and choose Update 6 from the drop-down box in the download area.
For now you are fine with the Parallel Composer 2011 you are regsitered for and don't care about the different products.
You may have a look at the product page to sort out whether you may need the full package of compiler and profiling/correctness tools (Parallel Studio or Parallel Studio XE for Windows) or just the compiler tools (Parallel Composer or Composer XE).
Product page: http://software.intel.com/en-us/intel-sdp-home/
Hubert.
Thanks! Any feedback on the compiler is very welcome.
Hubert.
