Intel® C++ Compiler
7833 Discussions
OpenCV compilation with Intel C++ Compiler
Engin_F_
Which compiler flags should be used for OpenCV compilation to get best performance from library?
I want to benefit from vectorization properties of compiler and want machine code of OpenCV which fully benefits SSE and AVX instructions.
At least some clues about this issue will be fine for me.
SergeyKostrov
Valued Contributor II
>>Which compiler flags should be used for OpenCV compilation to get best performance from library?.. It would be nice to see a set of Intel C++ compiler options you currently use. Take into account that some Intel C++ compiler options are turned on by default and use icl.exe -help. Here is a list you could try: /O3 /QaxSSE2 and /QaxAVX /Qvec /Qstd=c99 /Qrestrict /Qansi-alias /Qipo /Qunroll=8 /Qopt-block-factor:3 /Qopt-mem-layout-trans:3 /Qopt-prefetch:4
SergeyKostrov
Here are two sets of compiler options to be considered: [ Intel C++ compiler ] /O3 /Oi /Ot /Oy /GF /MT /GS- /fp:fast=2 /W5 /Wp64 /Zi /Gr /TP /Qopenmp /Qfp-speculation:fast /Qopt-matmul /Qparallel /Qstd=c++0x /Qrestrict /Qunroll:4 /Qopt-block-factor:64 /Qopt-streaming-stores:auto [ Microsoft C++ compiler ] /O2 /Oi /Ot /Oy /GF /Gm /MT /GS- /fp:fast /openmp /W4 /Wp64 /Zi /TP /errorReport:prompt Note: /Ox ( Full Optimization ) could be used instead of /O2
Engin_F_
I will give them a try and share the results, thank you so much.
SergeyKostrov
>>...I will give them a try and share the results... The best way to continue is to add, or change, one option at a time with verification in Release Configuration that performance doesn't get worse. If you try all of them at the same time and performance gets worse then you won't know which option(s) is responsible for negative impact.
Engin_F_
Himm that's a very good idea. I will give them try in a batch. Whenever I complete my profiler, I will compile different builds of OpenCV by using this way and profile these different builds. I will share profiler results with you.
Thank you so much for your concern.
Bruno_A_1
Is there any recommendations based on personal experience? I'm currently compiling opencv with icc and would appreciate any pointers.
thanks
Bernard
Black Belt
Try to compile openCV programs with various compiler settings and later test your code with Intel VTune profiler.
Bernard
Black Belt
>>>fp:fast=2>>>
Instead of /fp:fast compiler option you can use more safe /fp:precise.
Dinesh_C_
HI,
   I want to compile  Opencv codes for image processing in Ubuntu, but when i use only the processor to run the code it's slow and for more reliability i want to use the Intel C/C++ compiler what are the changes that should be made in order to make it work. i found the Cmake cchanges and tried it but still it did'nt get through it completely.
Dinesh.
