I tried to get an OpenMP 4.0 test case to run where the code calls a user library that is compiled for host and mic (-mmic)
The host library is in current directory (pwd), the MIC lib is in pwd/mic and I set LD_LIBRARY_PATH to pwd and MIC_LD_LIBRARY_PATH to pwd/mic
However the execution fails with "On the sink, dlopen() returned NULL. The result of dlerror() is "/tmp/coi_procs/1/31669/load_lib/iccoutysEa1j: undefined symbol: foo"
Code look like this:
#include <omp.h> #include <stdio.h> #include <unistd.h> #include <stdlib.h> #include "foo.h" #pragma omp declare target int foo(); #pragma omp end declare target int main() { /* start user code */ #pragma omp target { foo(); } return 0; }
Command line is:
icc -shared -fPIC -o libhostlib.so hostlib.c
icc -mmic -shared -fPIC -o mic/libhostlib.so hostlib.c
icc -openmp -o test_mic.o -c test_mic.c
icc -openmp -L. -lhostlib -o test_mic test_mic.o
Why isn't this working?
Of course the topic title should be "...OpenMP 4.0 target directives ..." but I cannot edit.
