Intel® C++ Compiler
OpenMP 4.5 array reduction not working under Intel C++ 17.1.132
Marcin_M_
According to the OpenMP website, Intel C++ 2017 supports OpenMP 4.5: http://www.openmp.org/resources/openmp-compilers/
I created an OpenMP 4.5 compliant code, which compiles fine under GCC 6.3.1:
    vector<double> res(n);
    double* results = res.data();
    #pragma omp parallel for reduction(+: results[:n])
    for(int s = 0; s < n; ++s) {
        // do something
    return res;
This triggers a compilation error:
/home/marmstrz/pw-brandes/brandes.cpp(15): error: no matching declaration for this reduction
Why doesn't this work with the Intel compiler?
Judith_W_Intel
It works fine for me with our latest supported 17.0 compiler. I only see the error with the 16.0 compiler.
sptel42-171> cat openmp.cpp
#include <vector>
using namespace std;
vector<double> foo(int n) {
         // do something
   return res;
sptel42-172> icpc -qopenmp -c openmp.cpp
sptel42-173> which icpc
/site/spt/usr13/jward4/workspaces/17_0cfe/dev/build_objs/efi2linux_debug/bin/icpc
sptel42-174>
Marcin_M_
What is the version of your compiler? Mine:
$ icpc --version
icpc (ICC) 17.0.1 20161005
$ which icpc
/opt/intel/compilers_and_libraries_2017.1.132/linux/bin/intel64/icpc
Fogerty__Shane
Was there ever any resolution to this? I am experiencing the same thing.
I get the error:
    #pragma omp parallel for reduction(+:a[0:N]) private(j)
when trying to compile (with Intel 17.0.0 or 17.0.4) the OpenMP 4.5 example from http://www.openmp.org/wp-content/uploads/openmp-examples-4.5.0.pdf at the bottom of page 238. I can compile with gcc. I copy the code here:
#include <stdio.h>
#define N 100
void init(int n, float (*b));
int main(){
int i,j;
float a, b;
init(N,b);
for(i=0; i<N; i++) a=0.0e0;
for(i=0; i<N; i++){
  for(j=0; j<N; j++){
    a +=  b;
printf(" a[0] a[N-1]: %f %f\n", a[0], a[N-1]);
return 0;
Sheridan-Methven__Ol
I am experiencing the same problems. I have gcc version 7.2.0 and have tried compiling the following with icc versions 17.0.1 (20161005) and 18.0.0 (20170811). Currently it only compiles using the version 18.0.0 of icc. Using gcc works fine.
(icc version 18.0.0)user:temp$ icc -qopenmp -std=c99 demo.c -o demo
(gcc version 7.2.0)mimic:temp% gcc -fopenmp -std=c99 demo.c -o demo
(icc version 17.0.1)mimic:temp% icc -qopenmp -std=c99 demo.c -o demo
demo.c(9): error: no matching declaration for this reduction
  #pragma omp parallel for reduction(+:results[:n])
compilation aborted for demo.c (code 2)
The C code is for demo.c is
#include <stdio.h>
#include <stdlib.h>
#include <omp.h>
int main()
    unsigned int n = 5;
    double *results = (double *) calloc(n, sizeof(double));
    for (int s = 0; s < n; ++s)
        results += 1 << s;
    double res = 0;
    for (int i = 0; i < n; i++)
        res += results;
    printf("The sum is %f\n", res);
    return 0;
