Is there any way to determine the actual number of threads executing in a C++ program during an omp parallel for construct?
How can I tell if the number set by omp_set_num_threads() differs from the number returned by omp_get_num_threads()?
Chris
Hi Chris,
It is possible to determine the number of threads executing in omp parallel region. You can use the omp_get_num_threads() function in the parallel region to get the total number of threads your omp parallel region is using.
You can also assign the total number of threads to your parallel region using the num_threads(<value>) function.
The omp_set_num_thread(<value>) is runtime function to request certain number(value) of threads that you parallel region will use. Whereas the omp_get_num_threads() function will show you the number of threads used. So as long as you don't change the value of total thread the parallel region ( omp_get_num_threads() ) will always give the same value as that of omp_set_num_thread(<value>).
For more details, please refer to the below code.
#include <omp.h>
int main(){
omp_set_num_threads(4);
printf("%d\n",omp_get_num_threads()); //This will always return 1 as its not present in parallel region.
#pragma omp parallel
int total_td = omp_get_num_threads(); // This will always give the total number of threads used in parallel region.
#pragma omp for
for(int i=0;i<5;i++){
printf("Iteration %d is processed by %d/%d thread\n", i, omp_get_thread_num(), total_td);
printf("\n");
#pragma omp parallel num_threads(3)
#pragma omp for
return 0;
Warm Regards,
Abhishek
Hi Chris,
#include <omp.h>
int main(){
#pragma omp for
printf("\n");
#pragma omp for
return 0;
Warm Regards,
Abhishek
Hi Chris,
Thank you for the confirmation. As your issue is resolved we will no longer monitor this thread.
Please post a new thread if you have any issues.
Warm Regards,
Abhishek
