Yes, I know the OpenMP 3 standard does not specify what, if anything, atomic does and OpenMP 4 says to follow C++ (which is almost equally ambiguous), but the Intel compilers seem to take the sensible line of delivering sequential consistency for explicit atomic sections. The following program shows a case where that fails. Look at lines 244-246 in the output, which are:
Validating capture in OpenMP using volatile and y = x; x += v with atomic
There were at least 749115 breaches of sequential consistency (NOT expected)
It should be easy enough to find the code that causes the problem - sorry about not stripping down, but I am tied up with other work!
Hello, is this for C++ Compiler 14.0 Beta?
Yes. And 13...183. Sorry for not saying.
confirming a bug.
thanks for a reproducer. it was sent to appropriate people.
--Vladimir
