I have this code:
std::vector<Wrapper> localWrappers; std::vector<float> pixelDistancesNew; std::vector<float> curSigmas; //fill the 3 vectors #pragma omp parallel for collapse(2) schedule(dynamic, 1) for(int i=0; i<localWrappers.size(); i++) for (int r = par.border; r < (localWrappers.cur.rows - par.border); r++) for (int c = par.border; c < (localWrappers.cur.cols - par.border); c++) { const float val = localWrappers.cur.at<float>(r,c); if ( (val > positiveThreshold && (isMax(val, localWrappers.cur, r, c) && isMax(val, localWrappers.low, r, c) && isMax(val, localWrappers.high, r, c))) || (val < negativeThreshold && (isMin(val, localWrappers.cur, r, c) && isMin(val, localWrappers.low, r, c) && isMin(val, localWrappers.high, r, c))) ) // either positive -> local max. or negative -> local min. localizeKeypoint(r, c, curSigmas, pixelDistancesNew, localWrappers); }
And I get this error:
error: parallel loops with collapse must be perfectly nested for(int i=0; i<localWrappers.size(); i++) ^
Error: the OpenMP "single" pragma must not be enclosed by the "for" pragma
Reading [this](http://dev-archive.ambermd.org/201509/0004.html), I think that the error is given by the fact that we I'm using `size()`. However, I don't know how could I get `const` for this or implementing any kind of solution for this problem.
Can someone help me with this?
This is Wrapper definition:
struct Wrapper{ Wrapper(const SIFTDescriptorParams &sp, const AffineShapeParams ap) : sift(sp), ap(ap), sp(sp), mask(ap.smmWindowSize, ap.smmWindowSize, CV_32FC1), img(ap.smmWindowSize, ap.smmWindowSize, CV_32FC1), fx(ap.smmWindowSize, ap.smmWindowSize, CV_32FC1), fy(ap.smmWindowSize, ap.smmWindowSize, CV_32FC1) { computeGaussMask(mask); patch = cv::Mat(ap.patchSize, ap.patchSize, CV_32FC1); fx = cv::Scalar(0); fy = cv::Scalar(0); descriptors.reserve(500); } AffineShapeParams ap; SIFTDescriptorParams sp; cv::Mat1f descriptors; cv::Mat patch; std::vector<Keypoint> keys; cv::Mat high; cv::Mat prevBlur; cv::Mat blur; cv::Mat low; cv::Mat cur; SIFTDescriptor sift; cv::Mat mask, img, fx, fy; std::vector<unsigned char> workspace; }
Could you please share with us a test case which includes the definition for "Wrapper" to make sure we can inspect the optimizations under the hood?
I added the Wrapper definition, is anything else necessary? I'm afraid to make the question code too much confusing if I add other stuff
Your question gave me the hint and I found a solution. This line is the problem:
Instead, declare above the loop:
const int numRowsWithoutBorder = localWrappers.cur.rows - par.border;
Perhaps the size() is also a problem, as you said. So that the code should look like
std::vector<Wrapper> localWrappers; std::vector<float> pixelDistancesNew; std::vector<float> curSigmas; const size_t localWrappersSize = localWrappers.size(); const int numRowsWithoutBorder = localWrappers.cur.rows - par.border; //fill the 3 vectors #pragma omp parallel for collapse(2) schedule(dynamic, 1) for(int i=0; i<localWrappersSize; i++) for (int r = par.border; r < numRowsWithoutBorder; r++) for (int c = par.border; c < (localWrappers.cur.cols - par.border); c++) { ... }
If you want to use collapse(3), you'll have to do the same with the columns. This kind of thing worked for me with Intel 2018. I couldn't find any documentation about this behavior easily.
