Intel® C++ Compiler
OpenMP linking problem
ijjys
When I use the /Qopenmp compilation option, then at linking time the linker complains about some undefined references on a class destructor of my program. The thing is that without /Qopenmp, it compiles and links fine.
Is this a known bug? I cannot find a simple test case to show you the problem...
I use Visual 2008 with Intel compiler 11.1.065 [IA-32]
ijjys
The .i files (preprocessed files) of the .obj that returns the linker error is exactly the same with and without "/Qopenmp". The difference is setting libiomp5md.lib, because it causes an unresolved reference of part of my code.
Thanks in advance!
JenniferJ
Please check this article to make sure to link with only IntelC's openmp runtime: http://software.intel.com/en-us/articles/how-to-use-intelr-compiler-openmp-compatibility-libraries-on-windows/
Jennifer
ijjys
I think I'm doing that well:
Compiling:
/c /O2 /Ob2 /I "G:\blabla\include" /D "WIN32" /D "_WINDOWS" /D "NDEBUG" /D "_SECURE_SCL=0" /D "_SECURE_SCL_THROWS=0" /D "_HAS_ITERATOR_DEBUGGING=0" /D "_WIN32" /D "__INTEL_COMPILER" /D "_SCL_SECURE_NO_DEPRECATE" /D "DEBUG" /D "CMAKE_INTDIR="Release"" /D "_WINDLL" /D "_MBCS" /EHsc /MD /GS /fp:fast /Fo"blabla.dir\Release\" /nologo /TP /Zm1000 /Qopenmp -w
Linking:
kernel32.lib user32.lib gdi32.lib winspool.lib shell32.lib ole32.lib oleaut32.lib uuid.lib comdlg32.lib advapi32.libiphlpapi.lib /OUT:"G:\...blabla.dll" /VERSION:1.0 /INCREMENTAL /nologo /LIBPATH:"G:\....\Release" /MANIFEST /MANIFESTFILE:"blablat.dir\Release\blabla.dll.intermediate.manifest" /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /TLBID:1 /DYNAMICBASE /NXCOMPAT /IMPLIB:"G:\blabla.lib" /DLL DelayImp.lib /subsystem:console
Notice that even without linking libiomp5md.lib, the error appears. Its the same linking with it:
1>object1.obj : error LNK2001: smbolo externo "public: __thiscall A::~A(void)" (??1A@@QAE@XZ) sin resolver
The A class is not used there (only included on a included file). This destructor is the only symbol unresolved.
Thanks!
JenniferJ
Can you attach the .i file? It looks like there is a bug when compiling with /Qopenmp.
Do you have any openmp pragma in the .i file? if not, try to remove /Qopenmp for this one file, it should build ok.
Use "private" if you'd prefer. Or use the Intel Premier Support.
thanks,
Jennifer
ijjys
I`ve answered using the private option. It`s OK the file submitted?
Thanks!
JenniferJ
Thanks for the .i file.
There is a bug in the omp compilation. when /Qopenmp is applied, the .obj will have the symbol:
>>dumpbin /symbols n.obj | find /I "?1fest3@@QAE@XZ"
14E1 00000000 UNDEF notype () External | ??1fest3@@QAE@XZ (public: __thi
scall fest3::~fest3(void))
Using /Od /Ob0 doesn't work-around the problem. Well, let me see if the compiler engineer will have a work-around.
thanks,
Jennifer
ijjys
It also happens with my x64 compiler.
Ok, I'm awaiting you answer
Thanks again!
Alexander_W_Intel
the bug is finally fixed the Version 12.0 update 4 and later. There is no fix for the Version 11.1 - sorry. But there is a workaround for older versions.
The work-around: add a destructor instead of using the default one. The destructor can be empty. It's only important that it is defined explicitly.
Example:
[cpp]class A
public:
    A() {}
    ~A() {}
[/cpp]
Alex
