Intel® C++ Compiler
7831 Discussions
OpenMP tasking issues in ICL and ICX
AndrewC
New Contributor III
I believe there are  numerous problems with OpenMP tasking in ICL 2021.6.0  ( I suppose never to be fixed) and in ICX 2022.1.0
I will stand corrected by an OpenMP guru if my code is bogus! But I can't see anything wrong.
Problem #1
ICL compiled code executes incorrectly ( this has been extremely annoying) while ICX or (clang) compiled codes runs as expected - example function fails_intel_icl()
Problem #2
ICL compiled code executes correctly, but ICX/Clang code crashes at runtime  - example function crash_icx_2022()
Problem #3
ICL compiled code executes correctly, but ICX/Clang will not even compile -example function clang_wont_compile()
I built and tested these projects using Visual Studio 2022/ Debug/x64 testing with the Classic Intel C++ compiler and Intel C++ 2022 compilers as well as Visual C++ Clang compilers.
The Problem #1 is quite a nasty issue. When compiled with ICL, the function fails_intel_icl() launches a series of tasks. Output will be different each time but the key thing to note is that some 'tasks' for a pair of integers never run, and  other times you will get "duplicate" tasks for the same pair of integers. When compiled with ICX/Clang the tasks all get executed as expected.
// this compiles and runs incorrectly under icl but runs correctly with icx or clang
void fails_intel_icl()
#	pragma omp parallel
#	pragma omp single
			for (auto iter = data.begin(); iter != data.end(); ++iter)
				const auto a = iter->first;
				const auto b = iter->second;
				for (const auto aa : b)
					if (aa != a)
#pragma omp critical
							std::cout << "Thread:" << omp_get_thread_num() << " launching task for " << ' ' << a << ',' << aa << std::endl;
#	pragma omp task
							DoTask(a, aa);
Full Code
#include <iostream>
#include <vector>
#include <omp.h>
std::vector<std::pair<int, std::vector<int>>> data;
void setup()
	std::vector<int> tmp({ 1,2,3,4,5 });
	for (int i = 0; i < 5; i++)
		data.push_back({ i,tmp });
void DoTask(int a, int b)
		std::cout << "Thread " << omp_get_thread_num() << ' ' << a << ',' << b << std::endl;
// runs correctly under icl, but crashes at runtime with icx and clang
void crash_icx_2022()
#	pragma omp single
				const auto& a = iter->first;
				const auto& b = iter->second;
				for (const auto& aa : b)
					if (aa != a)
#	pragma omp task
							DoTask(a, aa);
#	pragma omp single
					if (aa != a)
#	pragma omp task
							DoTask(a, aa);
// wont even compile with icx or clang, but runs correctly with icl
#ifndef __clang__
void clang_wont_compile()
#	pragma omp single
			for (const auto& [a, b] : data)
					if (aa != a)
#	pragma omp task
							DoTask(a, aa);
#endif
void testTaskingBug()
	setup();
	std::cout << "Starting test using copies  iter " << std::endl;
	fails_intel_icl();
	std::cout << "Starting test using references and iter " << std::endl;
	crash_icx_2022();
#ifndef __clang__
	std::cout << "Starting test using C++17 loop " << std::endl;
	clang_wont_compile();
#endif
int main()
	testTaskingBug();
	return 0;
AndrewC
New Contributor III
I found the clang compiler error when compiling the function clang_wont_compile() is a long standing standards issue with capturing structured bindings in C++17 that compilers interpret differently and is supposed to be cleared up by the C++20 standard. It can be worked around quite easily
AndrewC
New Contributor III
I have tested with clang version 14.0.6 and it does not crash on the code that crashes icx at runtime. So obviously clang has been fixed in a version later than whatever icx is based on.
NoorjahanSk_Intel
We are working on your issue. We will get back to you soon.
Thanks & Regards,
Noorjahan.
Viet_H_Intel
For issue #1:  At some point in the future, the classic C/C++ compilers will enter “Legacy Product Support” mode signaling the end of regular updates to the classic compiler base, and they will no longer appear in oneAPI toolkits. So, the change to get this fixed in icl is very low. Please see https://www.intel.com/content/www/us/en/developer/articles/technical/adoption-of-llvm-complete-icx.html
For issue #2: I think you had reported this issue to us before and it's a known issue from LLVM community https://bugs.llvm.org/show_bug.cgi?id=33678
For #3: I will check our internal compiler to see if it still crashes or not and will update you.
Viet_H_Intel
I checked and didn't see the crash with upcoming compiler.
Viet_H_Intel
We've released oneAPI 2022.3. Can you upgrade to this version and let us know if you still have issue?
AndrewC
New Contributor III
I upgraded to One API 2022.3, but unfortunately encountered two blocking issues that have forced me to revert to OneAPI 2022.2
Viet_H_Intel
Unfortunately that you hit other issues, but did it fix the original OpenMP problems you initially reported in this thread?
AndrewC
New Contributor III
Yes it is fixed in the OneAPI 2022.3 distribution
Viet_H_Intel
Let's close this thread as fixed. Please create new tickets for other issues you encountered with oneAPI 2022.3
