tried to build latest OpenSSL with Qprof-gen, then internal error happenes. IERROR_MODULE_ID_1178
Feilong H (Intel) wrote:
Hi vush,
I downloaded openssl-1.0.1e. It appears that there are some configuration steps I need to follow, before compiling a specific source file. Here is what I did (according to INSTALL.W32). No errors.
> perl Configure VC-WIN32 no-asm
> ms\do_ms
> nmake -f ms\ntdll.mak
Then I tried to compile the file you mentioned. Unfortunately, I got the following error. Do you happen to know what else I need to do?
C:\Issues\U498713\openssl-1.0.1e> icl -Iinclude /Qprof-gen:globdata /Qprof-dir
"profile" -c .\crypto\modes\gcm128.c
Intel(R) C++ Compiler XE for applications running on IA-32, Version 14.0.0.103 B
uild 20130728
Copyright (C) 1985-2013 Intel Corporation. All rights reserved.gcm128.c
include\openssl/crypto.h(1): error: expected a declaration
../../crypto/crypto.h
^If not, could you please preprocess that file by typing the following command? Then upload the preprocessed file gcm128_prep.c in this issue.
> icl -Iinclude /Qprof-gen:globdata /Qprof-dir "profile" -E .\crypto\modes\gcm128.c -o gcm128_prep.c
Hi Feilong,
Seems like a sym link problem, on my platform is ok, I did not configure it to reproduce.
From your configure procedure, I did not configure it as no-asm. My procedure is:
> ms\do_nasm
But here you may not need nasm to config it, just use your previous build, and remove the 44-47 lines in openssl-1.0.1e\inc32\openssl\opensslconf.h
#ifndef OPENSSL_NO_ASM
# define OPENSSL_NO_ASM
#endif
Then icl -Iinc32 /Qprof-gen:globdata /Qprof-dir "profile" -c .\crypto\modes\gcm128.c
Maybe, some assembly code break the Qprof, but only on this file in OpenSSL.
Anyway, I uploaded the preprocessed file.
V.E.O
sorry for unfinished content, because the s*p*a*m filter never gonna pass my content. and i don't know which part is wrong, so i have to split it to many thread.
To reproduce this error:
1, download OpenSSL latest version openssl-1.0.1e
2, cd openssl-1.0.1e, and mkdir profile
3, icl -Iinclude /Qprof-gen:globdata /Qprof-dir "profile" -c .\crypto\modes\gcm128.c
Intel(R) C++ Compiler XE for applications running on IA-32, Version 14.0.1.139 B
uild 20131008
gcm128.c
": internal error: IERROR_MODULE_ID_1178
compilation aborted for .\crypto\modes\gcm128.c (code 4)
V.E.O
Is description of code 4 available to you?
never know related description about "internal error: IERROR_MODULE_ID_1178"
Hi vush,
> ms\do_ms
uild 20130728
Hi vush,
> ms\do_ms
uild 20130728
Hi Feilong,
> ms\do_nasm
#endif
V.E.O
Hi vush,
Thank you for your preprocessed file. I've reproduced the problem with it. Entered it to our problem-tracking database.
icc 14.0 update 3 contains a fix for this issue. FYI.
