I traced back a problem in an application release build to std::find returning the wrong result on the first call to it with an object not present in the collection but then the correct result on a second call. The attached demo code gives me this output from a release build:
Trigger 00000020F21DFDD0
Trigger 00000020F21DFDE8
Observer 00000020F21DFDD0
1
1
Observer 00000020F21DFE00
1 THIS SHOULD BE 0
0
A debug build or changing /O3 to /O2 or /Qstd=c++17 to c++14 and some other optimization option changes gives the correct results. Pulling the function body into main also gives correct results.
The problem is seen with Intel C++ 19.1.3 and 2020.1.
Environment and build details are in the demo file.
This seems like a serious optimizer bug.
Hi Stuart,
This issue is fixed in the oneAPI 2021.4 version. Kindly check and let us know if issue still persists.
Thanks!
Hi Stuart,
Thank you for posting in Intel C++ Compiler forum and providing us with the information about the issue, reproducer code and steps to reproduce the issue. We’re trying to reproduce it from our end. We'll get back to you. Thank you for your patience.
Gopika
Hi Stuart
We executed the reproducer code and we were not able to reproduce the issue. We tried with c++17, c++20 and c++14. We were getting the correct output. The ouput remains correct even if the options /O3 and /O2 are used. The details of our compiler are
>icl --version
Intel(R) C++ Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.1 Build 20201112_000000
Copyright (C) 1985-2020 Intel Corporation. All rights reserved.
We’d also set the compiler version to 19.1.3. We were not able to reproduce the issue.
As you tried in both Intel C++ 19.1.3 and 2020.1, we suggest you to install the latest version of intel C++ Compiler( i.e. 2021) and try running the code again. Please reach out to us if you’re still facing the issue after upgrading.
Gopika
Hi Gopika,
Thanks for the update. I think we have a real bug here so let's get the details right so the Intel team can reproduce this.
I just reproduced this on a different machine. Did you use the exact combination of flags shown in the demo file? I found that almost any change to those flags eliminates the bug.
icl /nologo /Qstd=c++17 /Qcxx-features /Qvc14.2 /QxHOST /Qansi-alias /DNDEBUG /O3 find_bug.cpp
If you used this then maybe it is hardware (/QxHOST) specific. The 2 systems I reproduced this on are Haswell CPU systems:
- Intel Core i7-4702HQ 2.20GHz running Windows 10 1909
- Intel Core i7-4790K 4.00GHz running Windows 10 20H2
The problem is present with /QxHOST replaced by /QxHASWELL and /QxSSE4.2 and /QxAVX and /QxCORE-AVX2 on these Haswell CPUs.
I reproduce the issue running Intel C++ 19.1.3 and the OneAPI 2021.1 Build 20201112_000000. There is no later Intel C++ to upgrade to (the 2021.2 update does not appear to include any compiler fixes).
Stuart
I am able to reproduce it and will work with our Developer for a solution.
FYI this bug is still present in the 2021.2.0 release, at least on top of Visual Studio 16.8.6.
I checked the internal bug report, this issue hasn't been fixed yet.
Can you add /Qhlo0 option as a workaround?
I can confirm that adding /Qhlo0 eliminates the error for the demo case with icl Version 2021.2.0 Build 20210228_000000.
Since this is an undocumented option can you provide information about what it does and whether it is likely to be better wrt performance than dropping back to /O2 or an earlier CPU /Qx?
Stuart
This option turns off some high level optimizations, but it's still better wrt performance than dropping back to /O2 or an earlier CPU /Qx.
Hi Stuart,
The issue is fixed in the oneAPI 2021.3 version. Please let us know if issue still persists.
Thanks!
Hi ArpitaP,
Unfortunately, the bug is still present in 2021.3.0 Build 20210609_000000 using the command line specified in the sample code. The same work-arounds still work including /Qhlo0 suggested by Viet_H above.
Not sure why the developers would tell you it is fixed when it clearly isn't.
Stuart
Hi Stuart,
Apologies for the confusion. I will let you know when the issue is fixed.
Thanks!
Hi Stuart,
Thanks!
Hi ArpitaP,
Yes, I can confirm that this is fixed in oneAPI 2021.4 with VS 2019 16.9.6.
Hi Stuart,
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks!
