Intel® C++ Compiler
7876 Discussions
Optimization miss with __builtin_expect
Margaret_B_
The following code
int foo(int a, int b)
   do
      a *= 77;
   } while (b-- > 0);
   return a * 77;
gets perfectly optimised into
foo(int, int):
..B1.2:                         # Preds ..B1.2 ..B1.1
        imul      edi, edi, 77                                  #4.6
        dec       esi                                           #5.12
        jns       ..B1.2        # Prob 82%                      #5.18
        imul      eax, edi, 77                                  #6.14
        ret
Adding a __builtin_expect in the loop condition
#define likely(x) __builtin_expect((x), 1)
#define unlikely(x) __builtin_expect((x), 0)
   do {
     a *= 77;
  } while (unlikely(b-- > 0));
   return a * 77;
produces terrible code no matter the likelihood advised.
foo(int, int):
        mov       eax, 1
..B1.2:
        xor       edx, edx
        test      esi, esi
        cmovg     edx, eax
        dec       esi
        imul      edi, edi, 77
        test      edx, edx
        jne       ..B1.2
        imul      eax, edi, 77
        ret
By simply introducing a redundant local variable
	int c;
	do
		a *= 77;
		c = b--;
	while (unlikely(c > 0));
   return a * 77;
the code generated improves
foo(int, int):
..B1.2:
        mov       eax, esi
        dec       esi
        imul      edi, edi, 77
        test      eax, eax
        jg        ..B1.2
        imul      eax, edi, 77
        ret
It seems that ICC get confused by the use of __builtin_expect, is this a bug of ICC or this GCC built-in is not fully functional yet?
Yuan_C_Intel
Hi, Margaret
Thank you for reporting this issue. I have reproduced it and entered it into our problem tracking system for a resolution.
I will let you know when I have an update on this.
Thank you!
Margaret_B_
Thank you, Yolanda
