I am trying to use the "Intel Processor Microarchitecture-Specific Optimization" setting that's available in Visual Studio when using the Intel C++ compiler (in properties under C/C++ >> Code Generation [Intel C++]). This is the same as the command-line /tune option. Right now I am using /tune:skylake to try to improve performance on a Xeon Server (a Xeon Platinum 8168, running a VM), but I am not seeing a performance improvement. What /tune option should I be using for this server?
- Tags:
- CC++
- Development Tools
- General Support
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
You could use Skylake and AVX2 on your desktop (and it will run on the Xeon Platinum 8168 processor)
But the Xeon Platinum 8168 processor could benefit from /QxCORE-AVX512
While both are Skylake series, your desktop Core i7-6700K has 2 memory channels, whereas the Xeon Platinum 8168 has 6 (as well as AVX512).
At this point in development (optimizaton), I would recommend first to work on your desktop targeting AVX2 and implement the indexing method as suggested in post #10. **** however keep the older pointer code in a conditional #if section for use in testing.
You will need to check the benefit or lack thereof for each ISA (AVX2 on desktop and server, and AVX512 on server).
The selection for use of the pointer method or index method should be relatively easy to integrate using #if defined(...) #else ... #endif
IIF your loop is (are) compatible with scatter/gather, then more of it can be vectorized without going through code contortions to get there. Presumably yielding significant performance improvements.
Jim Dempsey
- « Previous
- 1
- 2
- Next »
- « Previous
- 1
- 2
- Next »
